Like Tree34Likes
RC10B4/T4 Forum
Old 02-01-2010, 02:43 PM
  #11236
Mack_Mechanic's Avatar
Originally Posted by rcman1993 View Post
This is a disappointment because ae really needs to come up with some new instead of wasting their time with the b4.1 and t4.1. They are stupid. Secondly, they were lazy by changing just the molds of the schocks to new molds. They have been using the same molds from ten years ago I believe. Not dissing them but it is like the auto companies, they cut corners at every oppertunity instead of doing the right thing.
If it aint' broke...don't fix it...........
Mack_Mechanic is offline
Old 02-01-2010, 02:45 PM
  #11237
Trader Rating: 23 (100%+)
its not a NEW mold, basically what it is, is a identification for associated to see, they can now identify the new, older, and oldest kits now with the little ring. i think the new shock rebuild kits are sweet though because i have had extremely little leaking and when i did check the inside of my shocks for dirt, there was just about none!
not home is offline
Old 02-01-2010, 03:22 PM
  #11238
rcman1993's Avatar
Trader Rating: 33 (100%+)
Yah but they only made a new mold because the old ones were getting bad. It would of been more economical to design a new shock so they don't have to double mold because those are really expensive.
rcman1993 is offline
Old 02-01-2010, 03:54 PM
  #11239
nothing is wrong with what they have, they got rid of the older molds so they stick with the new ones. basically the ring signifies that they are new, not much of a hassle putting in a little step to make a ring. there isnt anything wrong with them. although they are fairly basic, they get the job done, and with the new rebuild kits they get even better.
not home is offline
Old 02-01-2010, 04:08 PM
  #11240
Does anyone have any suggestions for wheels for the B4 other than the standard dish white/yellow?
Noticed the white rulux wheels, would LOVE to get a set of black rims (even dish) but would prefer anything not dish and not white/yellow.
B4 front & back.
thanks
lusifur is offline
Old 02-01-2010, 04:10 PM
  #11241
B4 front & back.
thanks
RIT black dye on the white wheels will do it.
not home is offline
Old 02-01-2010, 05:12 PM
  #11242
oldandnew's Avatar
Do the new rebuild kits work as well in the old shocks? Have shocks from kits from a year and two years ago.
oldandnew is offline
Old 02-01-2010, 05:14 PM
  #11243
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
yes, same question. wouldnt want to have to sift thru shock rebuild kits. i usually go with orings only. but at least a fresh clip is nice.
R
UltegraSTI is offline
Old 02-01-2010, 05:25 PM
  #11244
The new shock rebuild kits work in the old shock bodies and have very little leaking compared to the old kits.
associatedboy is offline
Old 02-01-2010, 05:27 PM
  #11245
Registered User
UltegraSTI's Avatar
p# stayin the same as well? should i order em thru frank to assure that i get new pieces (this, towers, carriers, arms, steering stuff etc) or would LPH have em by now. dont feel like buyin any more old parts in lieu of this all.
R
Old 02-01-2010, 05:39 PM
  #11246
whitrzac's Avatar
Trader Rating: 96 (100%+)
Originally Posted by not home View Post
got off the phone with ae today, and just to let everyone know that the chassis hasn't changed at all, the only changes are the shock towers, the shock bodies are for sure the same thing as the old ones on the inside, just a ring to identify that they are newer. the steering parts are from the sc10 and have the same part number as well as the rear motor guard. i know some people were confused so here you go.
I call BS on the steering rack... the plastic is alot darker and softer than the older ones.
the sc10 motor guard is complatly diffrent that the T4 one...
just going from my used t4s and my new SC10
the plastic that the chassis, arms, tower, etc is diffrent than the my older T4s. everything seems to have more slop in it now too
whitrzac is offline
Old 02-01-2010, 05:40 PM
  #11247
assoc is correct, most lhs's should have them by now. and above, there isnt a new shock body, some stuff and its a world of a difference
not home is offline
Old 02-01-2010, 05:48 PM
  #11248
yeah...this is sc10 plastic, basically its a bit beefier but some of the guys arent too happy with the stuff breaking. and the steering knuckles are sc10 ones.
the sc10 motor guard is the same thing, same part number and it fits, associated is making one mold, getting rid another mold, and its nicer to carry around from the rear
probably carbon...
not home is offline
Old 02-01-2010, 08:55 PM
  #11249
Tech Legend
Wild Cherry's Avatar
So you know , the Sc-10 bell crank plastic is more flexible then the old plastic....
Wild Cherry is offline
Old 02-01-2010, 11:32 PM
  #11250
Your opinions... for a FT B4.
Tekin RS & Redline __.5
or
SXX Competition & X-12 __.5
or
_____________ & ________ ___.5
I've never owned either Tekin or LRP before, only run Castle products. Any advice?
Am currently leaning toward Tekin w/ a 10.5, but am very open to suggestions.
lusifur is offline
