Like Tree34Likes
RC10B4/T4 Forum
Old 01-29-2010, 10:23 PM
  #11191
Trader Rating: 23 (100%+)
Originally Posted by 440swinger-kid View Post
Hey guys I just got a 17.5 brushless and 7.5 for my B4 what do you guys suggest for gearing for each motor?
72/33 and 81/22ish
not home is offline
Old 01-29-2010, 10:27 PM
  #11192
440swinger-kid's Avatar
Trader Rating: 50 (96%+)
which one for the 33 pinion.... the 7.5?
440swinger-kid is offline
Old 01-29-2010, 10:38 PM
  #11193
noooooo unless you like smoke.
not home is offline
Old 01-29-2010, 10:48 PM
  #11194
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
what brands are they?
RC10B4_Mafco is offline
Old 01-29-2010, 11:05 PM
  #11195
both orions...... yeah I am horrible at re gearing stuff but am trying to understand....
Old 01-30-2010, 07:05 AM
  #11196
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
I am not sure about the other guys, but I would start at 27-28 with the 17.5 and 20-21 with the 7.5. Keep an eye on temps and wheel speeds and adjust from there.
I run 8.5 to 10.5 for all but the biggest smoothest tracks, then a 7.5 would be justified, imo.
....That said, i'm sure there are a ton of guys using 3.5 sedan motors in 2w.
lol,
...Jim
W.E.D.
www.wedjim.com
W.E.D.Jim is offline
Old 01-30-2010, 08:00 AM
  #11197
wayboarder's Avatar
Trader Rating: 14 (100%+)
lol,
...Jim
W.E.D.
www.wedjim.com
You have the 7.5 right.
However, with a 17.5 ya gotta be up at 34/72 or 35/72 if your using an SPX, higher if your running any kind of static timing ESC. If you are running the Tekin RS and have the vegas software, gear 30-32/72. The tekin and SPX can get away with that lower gearing because timing will make up for the RPM but on a static timing esc, you would be FAR undergeared.
wayboarder is offline
Old 01-30-2010, 10:06 AM
  #11198
Trader Rating: 27 (100%+)
Originally Posted by rcman1993 View Post
Check your solder job. It might need some work because when one of the wires is loose. It cogs really bad. Also, check the bearings in the tranny, I replaced mine when it started to grind alittle and it helped slot. My buddy has the same problem with you and it was the bearings. Funky sound was coming from what seemed to be the motor but it was the trans bearings.
ok I will do that, but see you would think I would have some power at least right? Cause I pull the trigger.... Cog.... Nothing.... Cog.... Nothing. lol
C_Money is offline
Old 01-30-2010, 12:28 PM
  #11199
farny21's Avatar
Trader Rating: 23 (96%+)
i got a used t4 and put my sidewinder in it and the diif didnt like that so i bought a rebuild kit, it just spun and didnt go anywhere so is there any tricks when i rebuild it to handle the brushless motor.
farny21 is offline
Old 01-30-2010, 02:15 PM
  #11200
B-FAST R/C's Avatar
Here is a step by step diff build created by B-Fast Team Driver Mike Barrett. Hope this helps.
http://www.rctech.net/forum/attachme...1&d=1264885804
File Type: pdf
B-FAST R/C is offline
Old 01-30-2010, 03:23 PM
  #11201
farny21's Avatar
thanks for the info, will help out alot.
farny21 is offline
Old 01-30-2010, 05:22 PM
  #11202
would you say a LRP Sphere Comp is a static timing ESC? and also could you gear down say a 8.5 in 2wd and then use a SPX or a Tekin RS to make up the top end with the timing up?
Thanks for any input,
Mark
Old 01-30-2010, 05:59 PM
  #11203
rcman1993's Avatar
Trader Rating: 33 (100%+)
Mark
Let's just say this. My 17.5 is competative against 13.5 and my 13.5 is competative against 10.5 because of my tekin rs. I love the boost on it. It is like having overdrive on a big ram 3500.
rcman1993 is offline
Old 01-30-2010, 06:19 PM
  #11204
well i am running a GTB....
Old 01-30-2010, 10:19 PM
  #11205
Trader Rating: 87 (100%+)
Hey guys, any secrets on how to keep tires glues onto the rims? When I originally glue the set, I had sanded dow the rim where the bead lays, and scuffed the tire bead and cleaned it with alcohol. And after checking to see if I had set-up my Tekin correctly, I noticed it had come unglued. To be honest, I'm about ready to start shoe gooing the tires one. That stuff really seems to work. Anyway, ideas anyone? I'm running a B4 and a T4 with a 13.5.
MUDVAYNE is offline
