Like Tree44Likes
RC10B4/T4 Forum
Old 01-26-2010, 05:26 AM
  #11146
whitrzac's Avatar
Trader Rating: 97 (100%+)
Originally Posted by not home
theres a lot of play in them, and the qc hubs wear fast. thats rly the only reason why i didnt like them. losi and kyosho dont have nearly as much.
add a shim in between the QC and the outer bearing. This will take care of allmost all of the slop
whitrzac is offline
Old 01-27-2010, 03:15 AM
  #11147
Default another gearing question...
i know this question has probably been beat to death, but i am wondering where i should start my gearing for a b4 with tekin rs esc and epic duo 2 17.5 motor running on a medium size indoor clay track. i'm also wondering where a good place to start is with boost and throttle profile with this set up. all help appreciated.
Koopa Troopa is offline
Old 01-27-2010, 04:00 AM
  #11148
rcman1993's Avatar
Trader Rating: 33 (100%+)
What software r u running. If it is 203 then go 81/22 and set motor can timing at 0degrees and set the esc to 45 degree timig with 5 boost. End rmp at 12000 rpm and start at 4000 rpm. Set timing ramp at 2. This works good for me.
rcman1993 is offline
Old 01-27-2010, 09:02 AM
  #11149
rripp's Avatar
aerayls asked a few questions a couple pages back about new parts in the B4...I received a B4 from AE today and it was on backorder for about a week, anyway, it has the new steering assembly, new spindle arms, new motor guard, new shock bodies and new shock inner plastic but does not contain the new towers or new chassis. I also ordered a spare front tower and it is the newer one. The newer front tower doesnt have the webbing on the back that interferes with the shock when using the inner hole.
rripp is offline
Old 01-27-2010, 11:24 AM
  #11150
Default good news
thanks rcman. yes i am running the 203 software.
Right on man this is good news.. is there going to be a redesigned rear shjock tower with a fourth hole? Lets hope so...
Old 01-27-2010, 12:24 PM
  #11151
rripp's Avatar
There is a new rear tower, just not in kits yet. It doesn't have four holes, just all the holes moved in one hole...if that makes sense?
rripp is offline
Old 01-27-2010, 02:57 PM
  #11152
Default yup
Awesome, so its like if the 4th hole was there and the 1st hole cut off (no one uses it anyway right?). sweet.
Old 01-27-2010, 03:01 PM
  #11153
Trader Rating: 23 (100%+)
yeah, nobody uses it.
not home is offline
Old 01-27-2010, 08:56 PM
  #11154
Bobby Z's Avatar
This is good news for those who are considering buying a new kit in their near future. I have heard about all the parts you mentioned except for the steering assembly. What has changed with them?
Bobby Z is offline
Old 01-27-2010, 08:58 PM
  #11155
Bobby Z's Avatar
i am running the closer to wheel camber setup as an experiment. it seems to smooth it out because it is moving the pivot point closer to the wheel so the effects of the camber linkage will occur earlier. i like it alot.
thanks for the reply. Sounds like I will need to test this next race night
bob
Bobby Z is offline
Old 01-27-2010, 09:10 PM
  #11156
Trader Rating: 88 (100%+)
Are these available for individual sale yet?
MUDVAYNE is offline
Old 01-27-2010, 09:37 PM
  #11157
What is different on the new steering rack, and where can I buy a new one?
cjcoffroad is offline
Old 01-28-2010, 01:50 AM
  #11158
Emlyn's Avatar
The steering rack is made of sc10 plastic now doesn't look any different just a darker plastic, my b4 i got a couple weeks ago had all the updates minus the towers..
Emlyn is offline
Old 01-28-2010, 07:15 AM
  #11159
chedda bob's Avatar
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 149 (100%+)
So what do the new shock bodies look like? I'm getting ready to put kyosho shocks on the back and am curious....
chedda bob is offline
Old 01-28-2010, 07:56 AM
  #11160
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
http://www.rctech.net/forum/6895199-post11085.html
CCristo is offline
