Like Tree34Likes
RC10B4/T4 Forum
Old 01-15-2010, 07:00 PM
  #10966
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
The two different chassis materials from my experience are best suited to different conditions. I mostly ran the plastic material, since it is less conductive for less interference(Back with Crystals and battery bars, lol) and because is seemed to "settle" the car down.
But, on smooth tracks with good traction, the FT chassis seems to help lap times a little. Unless of course you crash, then it's advantage is null and void, .
Keep in mind that some minor shock tuning will be needed from one to the other. I usually went a little softer on the rear spring with the stiffer material.
...Jim
W.E.D.
W.E.D.Jim is offline
Old 01-15-2010, 07:34 PM
  #10967
Trader Rating: 87 (100%+)
So what you're saying Jim is that on a slicker or looser track, the plastic is better, right?
MUDVAYNE is offline
Old 01-15-2010, 08:49 PM
  #10968
W.E.D.Jim's Avatar
Yeah, making the car a little lazier/softer, so you can stay ahead of it will help on loose as well as rough tracks.
...Jim
W.E.D.
Get Faster Gear
Old 01-15-2010, 10:31 PM
  #10969
Trader Rating: 23 (100%+)
ill agree to that. my truck does get real loose easily with that carbon chassis. the plastic does make it a lazier and calmer vehicle.
not home is offline
Old 01-17-2010, 07:46 AM
  #10970
Davidka's Avatar
Trader Rating: 85 (100%+)
So I built some new rear shocks but it seems I have a pair of the "bad bodies". The internal clip won't stay seated. Anyone know what the process for getting replacements from AE is?
Davidka is offline
Old 01-17-2010, 11:21 AM
  #10971
Before you get too carried away, have you checked the clip is the right way around? There is a slightly rounded edge and a more square edge. Make sure the squareer edge is facing up.
Also, have you tried sanding the plaster tube spacer a small amount? Sometimes it relieves a bit of pressure to allow everything to sit better.
JR007 is offline
Old 01-17-2010, 11:55 AM
  #10972
Davidka's Avatar
I have experience with Associated shocks going back to the first RC10's. I know how they're supposed to assemble, I know these bodies are not right. This problem is public knowlege, others have had their bodies replaced, I just wanted to hear how they got it done.
Davidka is offline
Old 01-17-2010, 12:06 PM
  #10973
Contact Don at AE
Chris Reilly is offline
Old 01-17-2010, 03:21 PM
  #10974
ace921000's Avatar
Check out my freshly built ft b4! I'm so excited.
Attached Thumbnails RC10B4/T4 Forum-b4.jpg   RC10B4/T4 Forum-b4-2.jpg
ace921000 is offline
Old 01-17-2010, 06:26 PM
  #10975
I am shure you have a bad set.The ones i have the clips almost fall out.Hope you know who to contact at ae,cause when i called they acted as if i was the only one with the problem.They never heard of a problem with there shocks lol.
BeefHead is offline
Old 01-18-2010, 06:14 AM
  #10976
d4man's Avatar
That happened to me, last year when I bought new cars to goto CRCRC. I talked to Don/Brent at AE and they got it fixed by sending me new threaded shock bodies for my T4 and B4.
d4man is offline
Old 01-18-2010, 08:51 AM
  #10977
Is there anything special I need to do to use the racers edge hubs? I installed them and the wheels bind when I tighten the nuts...
5p3ktrum is offline
Old 01-18-2010, 09:16 AM
  #10978
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
any update on the new plastic?
R
UltegraSTI is offline
  #10979
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
Sounds like you forgot the crush tubes that go on the axle, between the bearings.
CCristo is offline
Old 01-18-2010, 09:28 AM
  #10980
Trader Rating: 16 (100%+)
I had this problem with the racers edge hub, the crush tube is not long enough, add one thin black shim from the tc3 shim kit to each side of the crush tube and it should not bind anymore
Zach Phillips is offline
