Like Tree34Likes
RC10B4/T4 Forum
Old 01-04-2010, 03:03 AM
  #10816
1
Trader Rating: 30 (100%+)
Originally Posted by busta774 View Post
hey, im just getting back into electric and i have the b4 jus wondering what size pinion to run i am using a 8.5t brushless and a 81 spur, and just any ideas for a pinion to start on? i also have a few different size spurs 72 & 78
Hey buddy, try 24/78 works well. Is also the same as on some of the AE set-up sheets with 8.5.
1 is offline
Old 01-04-2010, 03:41 AM
  #10817
busta774's Avatar
Thanks everyone for the suggestions so i will try 24/78
Cheers
busta774 is offline
Old 01-04-2010, 05:34 AM
  #10818
Originally Posted by W.E.D.Jim View Post
JW91, sounds like you may also be ready for a stiffer rear spring.
...Jim
W.E.D.
Get Faster Gear
Now that the car is close and has a little understeer I think I'll try the cut black springs in the rear.
We'll see how it works.
I also put a 25/78 in it and the car is much more driveable with the 10.5.
JW91 is offline
Old 01-04-2010, 09:38 AM
  #10819
AssocRacer's Avatar
Originally Posted by kamicowzi View Post
Hey guys...I have a FT T4 that I just recently built and all of a sudden it has started thermaling and the motor is hot as hell to the touch. I just rebuilt the diff a day ago, and I am running a Novak Havoc 3s with a SS4300 (10.5) and i have it geared at 87/23. I was wondering if anyone has things I should take a look at.
I'm at 81/23 with a Novak 10.5/sintered rotor, but that's a race truck with a 7.2v lipo. As far as the stock 87 spur, the biggest pinion you can fit is a 25. If you're thermaling, you're not undergeared, your probably way over geared. I'd keep the same spur and just start going down 1 tooth on the pinion until it stops thermaling. Once you get it in the right ballpark the motor will feel alot better too.
AssocRacer is offline
Old 01-04-2010, 07:14 PM
  #10820
Any of you try kyosho shocks on you're b4?I got to try a set this week end,and realy liked them.
BeefHead is offline
Old 01-04-2010, 07:20 PM
  #10821
Tech Legend
Wild Cherry's Avatar
I love B-4's shocks .....
Wild Cherry is offline
Old 01-04-2010, 07:23 PM
  #10822
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
oh boy that issue again...
R
UltegraSTI is offline
Old 01-04-2010, 07:25 PM
  #10823
Trader Rating: 23 (100%+)
if lengths match up with some or no modification its not a terrible idea. im not sure is springs fit between vehicles or not which would be something else needed to sort out. i need new shock bodies for both vehicles and i need to try the new rebuild kits.
not home is offline
Old 01-04-2010, 07:27 PM
  #10824
rcman1993's Avatar
Trader Rating: 33 (100%+)
this is an oldy but goody argument. not to start anything but associated does need to update shocks that are 20 years old. i like them but a change is nice. it brings in money for them anyway.
rcman1993 is offline
Old 01-04-2010, 07:29 PM
  #10825
dont start any more shock argument, ae has released new shock bodies and rebuild kits for the new and the old kits.
not home is offline
Old 01-04-2010, 07:36 PM
  #10826
The set i try`ed had kyosho orange springs ,not shure about pistons.They fit perfect ,I had to unscrew the fronts two turns to get my droop the same.A softer spring in the rear would have been better.They worked very well,and no leaking lol.
BeefHead is offline
Old 01-04-2010, 07:37 PM
  #10827
rcman1993's Avatar
I'm not trying to start anything but they released new stuff. Shocker to me. Please put link so we can see unless you are talking about the threaded factory team ones that are still the same design.
Old 01-04-2010, 07:39 PM
  #10828
are the specs basically the same?
not home is offline
Old 01-04-2010, 07:40 PM
  #10829
Tech Legend
sazs U
Nothing available that can out perform um still...
Old 01-04-2010, 07:42 PM
  #10830
AE shocks are not the best... but there not the worst. I dont like them but thats just me.
x60Driver is offline
