Like Tree34Likes
RC10B4/T4 Forum
Old 01-02-2010, 09:52 PM
  #10801
Tech Legend
Wild Cherry's Avatar
X60
30 T !!!!
O-man .....
On the tracks I run on 10.5 would not perform very well with a 30T due to excess heat....
Wild Cherry is offline
Old 01-02-2010, 09:54 PM
  #10802
Originally Posted by Wild Cherry View Post
X60
30 T !!!!
O-man .....
MI tracks are on a good size. like 120 by 70. Long stights and some ok traction. My friend also ran the same gearing and we both never had a problem.
x60Driver is offline
Old 01-02-2010, 10:02 PM
  #10803
Tech Legend
bring it indoors on clay and try the 30T ....
Old 01-02-2010, 10:03 PM
  #10804
yeah i have before.
Old 01-03-2010, 06:45 AM
  #10805
busta774's Avatar
hey, im just getting back into electric and i have the b4 jus wondering what size pinion to run i am using a 8.5t brushless and a 81 spur, and just any ideas for a pinion to start on? i also have a few different size spurs 72 & 78
busta774 is offline
Old 01-03-2010, 10:29 AM
  #10806
Go to www.comeseethis.com to figure out a good starting point for your car.
CraigV is offline
Old 01-03-2010, 11:37 AM
  #10807
Trader Rating: 24 (100%+)
For a 8.5 in a b4 try 23 to 25/78. I usually run a 24/78 area with no heat issues and plenty of pop.
AxiomJacob is offline
  #10808
Default Overheating T4
Hey guys...I have a FT T4 that I just recently built and all of a sudden it has started thermaling and the motor is hot as hell to the touch. I just rebuilt the diff a day ago, and I am running a Novak Havoc 3s with a SS4300 (10.5) and i have it geared at 87/23. I was wondering if anyone has things I should take a look at.
kamicowzi is offline
Old 01-03-2010, 11:39 AM
  #10809
Your geared way to high for a 3S 11.1 V lipo setup. Drop to maybe a 18/87 and it should help a lot. The 4300 is also non sintered so it will lack the torque of a new 10.5
Old 01-03-2010, 11:41 AM
  #10810
Trader Rating: 23 (100%+)
depends on the size of the track, i tried 81/23 and 78/21 for a tighter track.
not home is offline
Old 01-03-2010, 11:51 AM
  #10811
I am only running 2s...it's just the Havoc 3s speedo.....I don't run 3s in any of my cars.
Old 01-03-2010, 03:28 PM
  #10812
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
JW91, sounds like you may also be ready for a stiffer rear spring.
...Jim
W.E.D.
Get Faster Gear
W.E.D.Jim is offline
Old 01-03-2010, 03:37 PM
  #10813
Since thats the case you are most likely under geared. I would try a 23/78 or 24/81 to start with and you can probably gear up from there.
Old 01-03-2010, 04:06 PM
  #10814
whitrzac's Avatar
Trader Rating: 96 (100%+)
is it binding anwere??
take the motor off and see if the spur spins freely by hand
whitrzac is offline
Old 01-03-2010, 11:14 PM
  #10815
Emlyn's Avatar
You are way undergeared, Id try 78s 25p or you could try 28p with 87 spur if it fits.
Emlyn is offline
