Like Tree34Likes
RC10B4/T4 Forum
Old 12-24-2009, 04:57 PM
  #10681
Tech Legend
Wild Cherry's Avatar
Originally Posted by not home View Post
ive already been thru this one before, they are cheap, i stripped the threads on the cap which screws into the shock body twice in a row, i removed the cap once to refill with oil and clean, then stripped when i tired to tighten down, no i didnt screw it up the first time when i put it on, or the second time, i know how to put on a shock cap.
O thats right,
Your the guy that cross threads his caps ....
Hardly Ae's fault or problem is it ?
Advise to be more careful threading the cap on ...
Wild Cherry is offline
Old 12-24-2009, 05:02 PM
  #10682
RDOUBLEDAY's Avatar
Originally Posted by Wild Cherry View Post
O thats right,
I have no problem with ae shock caps.
The way i do it is screw them on with my fingers then screw it on with the tools that the kit came with.
RDOUBLEDAY is offline
Old 12-24-2009, 06:58 PM
  #10683
astroboy403's Avatar
same here, not AE's fault.
astroboy403 is offline
Old 12-24-2009, 07:18 PM
  #10684
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
It helps to turn the cap backwards first until it drops down, this is the thread starting area. At this point it is important to make sure the cap is laying flat on the threads, you will know by weather or not it rocks on top of them. If it doesn't rock it is flat and ready to be threaded on.
I have never stripped an AE shock cap in 20+ years of building them. The only ones that were even remotely tuff over the years were the early Kyosho fine threaded shock bodies from the 80's, called Gold shocks.
Threaded aluminum is threaded aluminum, no matter who makes it, it takes care to keep from doing damage.
...Jim
W.E.D.
W.E.D.Jim is offline
Old 12-24-2009, 07:28 PM
  #10685
RDOUBLEDAY's Avatar
Finnaly someone who is on my side.
Ive had Ae's shocks for along time andnever had a single problem. Probaly just dont know what there doing.
Old 12-24-2009, 07:39 PM
  #10686
Davidka's Avatar
Trader Rating: 85 (100%+)
FWIW, not home's problem isn't his fault. I just built a new set of rear shocks and had to buy new caps, the threading was a different depth and I could not get the old cap to thread on correctly. I tried a set of the local AE team guys and had no problem, he confirmed that there had been a recent switch to deeper/different threads on the shock body/cap because there had been more problems with the old threads, I presume because of a part vendor change but don't know if that's why or not.
The caps don't suck, the bodies don't suck. They just don't always match if you have pieces from around the time of the change.
Davidka is offline
Old 12-24-2009, 07:45 PM
  #10687
RDOUBLEDAY's Avatar
Your right too.
But if they say that their going to two to three sets somethings obviously wrong.
Old 12-24-2009, 09:11 PM
  #10688
Trader Rating: 23 (100%+)
Your right too.
thankyou! screw you wild cherry, i know how to thread shock caps on.
not home is offline
Old 12-24-2009, 09:18 PM
  #10689
What Da Hell !!
There no differences in performance or quality between the two versions of the caps ...
If there were you would be able explain to me what is not up par ...
Bet you can't tell us what is the "bad" or "cheap" as you say .....
No AE did a piss Poor job on there caps I wasn't happy with them. They didn't change nothing about the cap just threw set screw in them. Same with there shocks. Every thing about AE shocks sucks.
x60Driver is offline
Old 12-24-2009, 09:53 PM
  #10690
but the new shock bodies are supposed to be nice, i guess ill try them out in my truck, it needs some new bodies.
not home is offline
Old 12-24-2009, 10:35 PM
  #10691
+1 LOL
BeefHead is offline
Old 12-24-2009, 11:21 PM
  #10692
Tech Legend
Not Home
Just because you can't screw a cap on, you should not blame Ae..
and again you still did not explain want is "cheap" or what is the "bad" you are claiming..
Old 12-24-2009, 11:28 PM
  #10693
RDOUBLEDAY's Avatar
Not Home
Just because you can't screw a cap on, you suck not Ae ....
You might not be right like the other gut said as time goes by ae changes threads. Maybe he had an older et of shocks and tried to put bleeders or the new caps on.It not always his fault.So dont go saying that people suck.
Old 12-24-2009, 11:37 PM
  #10694
Trader Rating: 30 (100%+)
My bleeder caps screw onto the shock body just fine....its the tiny 2-56 bleeder screws that strip out in the plastic for me.....just like all the other 2-56 screws they use in the kit. I can bleed a shock faster with the old caps than missing around with these bleeder screws.
Lowrance is offline
Old 12-24-2009, 11:40 PM
  #10695
Tech Legend
Was a proper response to his" screw you "...
However I did edit..
