Like Tree34Likes
RC10B4/T4 Forum
Old 12-23-2009, 06:12 PM
  #10666
rcman1993's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Keith Billanti View Post
Can anyone confirm what chassis comes in the FT T4 and B4 kits? I know in the past that they were obviously graphite= BUT- i have heard that the newer kits have been coming with the preferred plastic chassis.
I opened a kit today and the chassis looks identical to the plastic one my friend bought off the wall today.
anyone know the weight of a plastic chassis? Graphite?
thanks in advance
KB
take an ohm meter and check for resistance. plastic = no resistance and carbon = resistance.
rcman1993 is offline
Old 12-23-2009, 06:15 PM
  #10667
RDOUBLEDAY's Avatar
Originally Posted by BISBEE 248 View Post
how does cleaning a cars outsides help a seal inside..
thanks to ae shocks i have to work on my car every race now also cause they always leak..
i have never had a single problem with ae shocks. just build them right
RDOUBLEDAY is offline
Old 12-24-2009, 04:50 AM
  #10668
Default AE Shocks
Make sure you always replace the clip that holds the internals in place on a regular basis...
-CB
cb71x is offline
Old 12-24-2009, 07:12 AM
  #10669
-CB
OMG Just rebuilt my T4 with the new bleeder shock caps and upon first rebuild they are better than i have ever built them before. Makes oil changes so easy. Yahoo!
Bubonic-X is offline
Old 12-24-2009, 08:18 AM
  #10670
Davidka's Avatar
Trader Rating: 85 (100%+)
Still not sure what the big deal with the bleeder caps is? We've been using Yokomo bleeder caps for years already.
Davidka is offline
Old 12-24-2009, 08:40 AM
  #10671
Trader Rating: 23 (100%+)
yeah, i dont even like the bleeder caps, when mine wear out, which is going to be soon, im going back to the regular ones.
not home is offline
Old 12-24-2009, 09:23 AM
  #10672
Yeah I don't like them ether. They look like they just threw them togather. A piss poor job really.
x60Driver is offline
Old 12-24-2009, 09:32 AM
  #10673
Tech Legend
Wild Cherry's Avatar
The new caps perform just fine , makes bleeding the shock easy as cake ...
Otherwise the old caps perform just as good ...
Wild Cherry is offline
Old 12-24-2009, 09:57 AM
  #10674
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
What are these bleeder caps? I notice the caps in my new truck kit have these large knobs on them.. as if there was supposed to be a hole, that was never drilled...
Curious
Keith Billanti is offline
Old 12-24-2009, 10:08 AM
  #10675
Matt Trimmings's Avatar
Trader Rating: 168 (100%+)
Curious
if your truck came with the bleeder caps then 1 side has a hole drilled and the other doesnt. if you dont have any hole then maybe they forgot to drill it?
Matt Trimmings is offline
Old 12-24-2009, 10:53 AM
  #10676
no, those are just i guess the new ones, i saw them on the rack at my lhs, they are like the new molded ones or something. look like bleeder caps, just missing the hole. probably the same bad quality as the bleeder caps without the hole.
i do think they just threw the bleeder caps together, pretty cheap job by them.
not home is offline
Old 12-24-2009, 11:04 AM
  #10677
Trader Rating: 16 (100%+)
Had my bleeder caps since they came out on my b4 and b44. No problem here,
Zach Phillips is offline
Old 12-24-2009, 11:22 AM
  #10678
Tech Legend
What Da Hell !!
There no differences in performance or quality between the two versions of the caps ...
If there were you would be able explain to me what is not up par ...
Bet you can't tell us what is the "bad" or "cheap" as you say .....
Old 12-24-2009, 12:48 PM
  #10679
Originally Posted by Wild Cherry View Post
What Da Hell !!
ive already been thru this one before, they are cheap, i stripped the threads on the cap which screws into the shock body twice in a row, i removed the cap once to refill with oil and clean, then stripped when i tired to tighten down, no i didnt screw it up the first time when i put it on, or the second time, i know how to put on a shock cap.
not home is offline
Old 12-24-2009, 01:09 PM
  #10680
RDOUBLEDAY's Avatar
Default Heres my freshly built ft b4
It Didnt Come with any Window Masks.
But It Didnt matter
Attached Thumbnails RC10B4/T4 Forum-unknown.jpg   RC10B4/T4 Forum-unknown-1.jpg
