Like Tree34Likes
RC10B4/T4 Forum
Old 12-21-2009, 07:06 PM
  #10651
klaymon's Avatar
Trader Rating: 71 (100%+)
I added weight to get mine to ROAR minimum and it helped the handling quite a bit. I'm sitting right at 1524 grams. I actually cut two weight "slabs" and put them under the battery in the tray (I have a slightly undersize battery right now). One sits at the very back and one at the very front. By moving those back and forth in the tray I can get different handling characteristics. If I need more steering, I move the back one up a little bit. If I need more rear traction, I move the front one back.
klaymon is offline
Old 12-21-2009, 09:25 PM
  #10652
Zerodefect's Avatar
Default Tuned flex chassis?
Has anyone tried removing the sides of battery box and the vertical sides of the sidepods?
I saw a racer with this mod and He said it was for more flex from the plastic chassis. Removed allmost all of the battery box and most of the sidepod sides!
Zerodefect is offline
Old 12-21-2009, 10:21 PM
  #10653
porkchop's Avatar
i found that 1530 is good 1600 i had to stiffen my car up oil wise to much
porkchop is offline
Old 12-21-2009, 10:22 PM
  #10654
Trader Rating: 9 (91%+)
i was just going to ask that same thing, I am thinking of removing the sides of the battery box to make my Lipos fit
interplanet is offline
Old 12-23-2009, 12:10 AM
  #10655
Default Mounting servo horn
Does anyone knows why the instruction manual says to mount the servo horn 1 degree off center ? Thx Serge
Sergel is offline
Old 12-23-2009, 01:20 AM
  #10656
Tech Legend
Wild Cherry's Avatar
Default off-set servo horn
Must do in order to have equal left & right steering ...
Wild Cherry is offline
Old 12-23-2009, 01:53 AM
  #10657
This topic is such a mess so I can't find if this has been discussed before.
Anyways, have you guys listed which parts do I need to be able fit gear diff to my B4 FT?
The list that I found comparing SC10's and B4 FT's manuals:
Diffcase (parts #):
B4: 9574
SC10: 9826
T-plate:
B4: 9570
SC10: 9818
Diff outdrive bearings:
B4: 6903
SC10: 9832
And of course the gear diff: 9827.
Do I need all of these SC10 parts or is there anything else?
Have you tried the gear diff in your B4's and what kind of results have u had with it?
AiR2k is offline
Old 12-23-2009, 06:21 AM
  #10658
Krio's Avatar
Trader Rating: 159 (99%+)
Diffcase (parts #):
B4: 9574
SC10: 9826
T-plate:
B4: 9570
SC10: 9818
B4: 6903
SC10: 9832
You've got it right. Just the diff case, t-plate, diff bearings, and actual diff is needed. Everything else falls right in.
Can't speak for a b4, but most serious guys are putting the ball diff into the sc10 because it works better. Most discussion on the matter usually ends with "the ball diff has a slight advantage for performance while a gear diff just lasts".
Krio is offline
Old 12-23-2009, 10:33 AM
  #10659
wstuart's Avatar
Trader Rating: 117 (98%+)
shock build question
what does it mean to have "-2" limiters in the front shocks.
ive seen this on a few pro setup sheets, but i dont know how to build it.
im assuming the +1 limiter in the rear means I just put a thin shock piston from the rebuild unerneath the shock piston
wstuart is offline
Old 12-23-2009, 10:37 AM
  #10660
Trader Rating: 23 (100%+)
adding a +1 limiter is putting one limiter under your shock piston, a negative limiter is unscrewing your shock bottom one thread and on.
not home is offline
Old 12-23-2009, 01:06 PM
  #10661
astroboy403's Avatar
hey wild cherry,
did you ask browny about what pistons he runs in his B44.
thanks
astroboy403 is offline
Old 12-23-2009, 01:19 PM
  #10662
Davidka's Avatar
Trader Rating: 85 (100%+)
-2 means unscrew the shock end 2 turns from fully threaded on. This is to increase the shock length when using the front shock on the outer hole on the front arm. The +1 limiters are .030" nylon washers, not necessarily the same as the bushing pieces in the shock rebuild kits (never measured them myself).
Davidka is offline
Old 12-23-2009, 01:22 PM
  #10663
Tech Legend
Default Scott Brown's B-44 shock set-up
Ft 35W
#2 piston , one .030 limiter
Rear 30W
#1 piston, one .030 limiter
Old 12-23-2009, 06:57 PM
  #10664
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Can anyone confirm what chassis comes in the FT T4 and B4 kits? I know in the past that they were obviously graphite= BUT- i have heard that the newer kits have been coming with the preferred plastic chassis.
I opened a kit today and the chassis looks identical to the plastic one my friend bought off the wall today.
anyone know the weight of a plastic chassis? Graphite?
thanks in advance
KB
Keith Billanti is offline
Old 12-23-2009, 07:04 PM
  #10665
Trader Rating: 50 (98%+)
Originally Posted by Wild Cherry View Post
Ft 35W
Rear 30W
thats the same thing i run in my b44 and it works great for me.
also on the chassis question. yes the new kits should have the plastic chassis in them.
micrors4guy is offline
