RC10B4/T4 Forum
rayspeed
I searched an not been able to find the rayspeed hubs in stock anywhere. Does anyone have any suggestions.
I am told the 1/2* hubs are only wanted on low bite surfaces and that they make the car sketchy off power on higher grip surfaces. I fun the light setup on what I'd call a med/high grip surface (much more than a 10.5 get's a little touchy) and don't use the 1/2* hubs and the setup works very well for me and others at this track.
R/C Tech Elite Member
I run the CRCRC light setup with the RE .5 hubs on a super high bite clay track, I have'nt felt sketchy/twitchy with the hubs off or on power all the fast ae guys at my track run the RE .5 hubs.............my car was sooooo good last week I didnt even re-build my shocks etc. for this week......it was just perfect and Im hoping for the same results tonight from the car
^^ Good to hear. Did you have a chance to try them side to side? I'm just going on hearsay, I never had the .5's to try.
no bro, I have only ran the RE hubs......maybe I'll try the switch someday to actually feel the difference
does anyone find that the racers edge hubs hole diameter is way too small, and needs reaming for the hinge pin to go through easily?
and is there another easy way to remove broken ball studs in the RE hubs?
I have tried to drill the broken stud to use an ezy out, but the material is just too hard. Cannot get a grip onto the broken stud, as its broken too far down, and cannot pull it through the other side!
Trcr has a med high grip surface and we have all tried the .5 only to go back to the standard hub ...
Tip :
If you have not use losi #55 piston with 35w ft 30w r ?
You really should take the time and find out for yourself...
Tip :
Can someone tell me how to use the quick change hubs on the front??
I have seen it done just not sure how to do it, I have looked thru some of the thread but cant find the answer I am about to build a t4 and was wanting to run all the same wheels, Thanks Brad
someone posted a link on here of a conversion they made. i would, im just concerned about the play they will have in them, like the rears do, and i will have to replace the qc hubs more often too.
If I had the RPM hopup parts I think it'll make a much better basher and racer then the E firestorm if i put RPM parts on the t4. What do you think? It's all part support that's why. If not then I'll stay with my e firestorm and buy parts and just have to wait for them is something breaks. The T4 seems to have easy cheap hopup parts and they are everywhere. I just want to bash, and maybe have he racing performance too.
(I have this post my other thread but thought i'd get better luck here)
hey man send me a pm with your email i got a set up sheet to sned you that really good better then the crcrc set up and comes form a pro to just a differnt ryan
I race at the same track as trevor and I have tried the hubs side by side. It is very hard to drive without them the rear end is to loose with the setup without the hubs on our track
