Like Tree34Likes
RC10B4/T4 Forum
Old 02-25-2006, 02:56 PM
  #1006
killer89's Avatar
Trader Rating: 41 (100%+)
Originally Posted by rcdude19641
if either pegasus or socal has one im gonna be trying it on sunday
socal has them... but not the "pro" tuned versions. I dont think anybody has those yet.
killer89 is offline
Old 02-25-2006, 05:52 PM
  #1007
how much are they?
Chris Jarosz is offline
Old 02-25-2006, 07:07 PM
  #1008
killer89's Avatar
just called... the non-pro ones are $34.99
killer89 is offline
Old 02-25-2006, 08:10 PM
  #1009
ill be pickin 1 up then
Old 02-26-2006, 02:57 AM
  #1010
WheelNut's Avatar
tcmerf- I have tried the new bladder caps, and they seem to work very well. The only problem is that the caps are too tall to tighten all the way down, so they leak out of the top. To solve that you just file them down 1-2mm. I haven't yet used them in actual offorad condition, only on our carpet track, which has jumps and they worked well.
WheelNut is offline
Old 02-27-2006, 09:54 AM
  #1011
Tech Legend
Wild Cherry's Avatar
Never have had to use the bladder`s....
Shocks perform just great with out um....
Wild Cherry is offline
Old 02-27-2006, 04:40 PM
  #1012
ok guys i ran the Co27 at socal. they didnt have the pro model so i got the non pro and put banzai serrated brushes and a purple and a red spring on it. in my first qualifer i geared it 16/84 in my T4 and it ran like a dog. i then remembered about gearing it high so i geared it 20/84. that was a huge mistake. the arm started to fall apart so i took it back to the shop and mike replaced it for free i broke in the new brushes and geared it 18/84 and all i can say is WOW. the motor had enough torque clear anything on the trackk and then some (the track had a giant triple that people in sportsman couldnt even clear. on the straight the motor was fast as hell. i didnt do so well in qualifing cause of the gearing problems but in the main i was outrunning people like crazy. i had a couple of bad crashes that put me in 4th. then i messed up on the triple and a marshell ran and bent down to pick up my car then left it so he could marshall his dad . i have to give the motor 9/10 just cause the instructions didnt say anything about offroad gearing
Old 02-27-2006, 07:22 PM
  #1013
DUB_Ben's Avatar
Finished building my FT T4. I have a GTB 6.5 geared 17/87 and it runs great! I just need to paint the body now.
DUB_Ben is offline
Old 02-28-2006, 09:12 AM
  #1014
I'm running a 16/87 on my GTB 5.5 (with HPI Yokohama tires) I'm gonna try 15/87.
What pinion does everyone think I should run on Masher2000 tires for some good ol' bashing?
Never tried running a 84 spur...
wyattburp is offline
Old 02-28-2006, 11:02 AM
  #1015
nutfluff's Avatar
Why are you running an 84 spur in your T4 at SoCal? That motor geared 87/20 is great.
nutfluff is offline
Old 02-28-2006, 11:48 AM
  #1016
The CO27 is the real deal. It requires a different approach to gearing (which would be a good reason to include off-road recommendations in the instructions...) but once you hit the sweet spot, this motor is definitely next-level.
Jason B is offline
Old 02-28-2006, 11:51 AM
  #1017
Originally Posted by Butters37
Im still up in the air about the graphite plastic debate. Plastic has more flex so it will provide better stability and better grip on a loose track. But I race in the Midwest where alot of the tracks are smooth and high bite clay. What i do is take a graphite chassis with me everywhere and i will swap them periodically throughout testing to see what works best. Has anybody else tried putting a 0.030 piece of lexan under the batteries?
I've lined my entire battery compartment with AE's chassis protection tape. It's durable, easy, and effective.
BTW, after getting my new B4 dialed, my BK2 doesn't hold a candle .
Jason B is offline
Old 02-28-2006, 07:06 PM
  #1018
DUB_Ben's Avatar
The B4 and T4 own the Bk2 and MF2.
DUB_Ben is offline
Old 02-28-2006, 08:03 PM
  #1019
Trader Rating: 19 (100%+)
Have you tried taking the oring off the shock body where the cap screws on? If you do that then you shouldn't have a problem.
Chris Brown is offline
Old 02-28-2006, 08:05 PM
  #1020
jamescam's Avatar
I was thinking 19/87 is where I will start with the C027 this weekend, will go up from there.
jamescam is offline
