Like Tree34Likes
RC10B4/T4 Forum
Old 09-30-2009, 09:32 AM
  #9721
Tech Legend
Wild Cherry's Avatar
Originally Posted by jdeadman View Post
Alrighty I think I had it right to begin with how much slippage should the diff be doing? When I set mine up according to the manual with the transmission back together while holding the spur and one wheel, the slipper will move first but If I lock the brake I can get the diff to slip.
How much resistance should there be and how should it feel?
As said, follow the instructions....
Your diff should not slip at all, insert two thin screwdrivers into the slots of the out drives and try to turn the diff gear by hand, if you can turn the gear, its loose..
You should not be able to turn the gear by hand even with considerable force...
Wild Cherry is offline
Old 09-30-2009, 12:59 PM
  #9722
Racers edge makes a nifty diff building tool that when you slide the outdrive slots in the tool it holds the outdrives so they dont move then you try to spin the diff gear with your hand, if you cant move it your good. Had that tool forever works great. the part # is RCE7030. Hope it helps
HEY GUYS WHEN ARE THE SHOCK BLEEDER CAPS COMING OUT?
IT CANT TAKE THAT LONG
Bubonic-X is offline
Old 09-30-2009, 03:33 PM
  #9723
rcman1993's Avatar
Trader Rating: 33 (100%+)
same as yokomo, same company is making them but i bet that they are waiting for the selling rights from yokomo. legal stuff takes a while.
rcman1993 is offline
Old 09-30-2009, 03:46 PM
  #9724
losi guy's Avatar
Trader Rating: 38 (100%+)
the caps are supposed to be out early October but ya never know. Sooner the better, i need those bad.
losi guy is offline
Old 09-30-2009, 08:30 PM
  #9725
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Originally Posted by CCristo View Post
No, the diff adjusting screw goes on the right/passenger/pinion gear side of the tranny
Like I said I have been known to be wrong in the past.
Thanks CC, I now need to re look t mine lol
dirtdustingdavo is offline
Old 10-01-2009, 12:13 AM
  #9726
porkchop's Avatar
hmmm
porkchop is offline
Old 10-01-2009, 12:26 AM
  #9727
air8's Avatar
I use piano wire for this same purpose. The diff setting ends up way too loose though. It's much quicker for me personally to tighten the diff screw till you feel the spring fully compress. Then back off one-half of a turn. Near perfect everytime. But this is just what I have found to work best for me.
air8 is offline
Old 10-01-2009, 08:47 AM
  #9728
Trader Rating: 19 (100%+)
Default t4 gearing
What should I gear my T4 at for a small/medium indoor track. Iam using a tekin 13.5
trap121 is offline
Old 10-01-2009, 08:55 AM
  #9729
Midnight's Avatar
Trader Rating: 85 (100%+)
24/81
Midnight is offline
Old 10-01-2009, 09:05 AM
  #9730
I only have 75,78,83,87 for spurs and 21,23,and 26 for pinions.
trap121 is offline
Old 10-01-2009, 10:49 AM
  #9731
23/75 as per the totally awesome kick ass site http://www.comeseethis.com/gearing/gearing.htm
Craig
CraigV is offline
Old 10-01-2009, 10:54 AM
  #9732
Rasheed's Avatar
Default what is ideal?
I have seen that site before and like it. However, I always wondered how they decide what gearing is "ideal". Anyone know?
Rasheed is offline
Old 10-01-2009, 11:01 AM
  #9733
The "ideal" gearing is decided by the motor manufacturer, and therfore, is slightly on the conservative side.
I would start with what it says then measure the motor temperature. If it's less then 160f you can gear up. Be careful if it goes higher, getting to 175 is not good, getting to 200 is bad and can ruin the motor.
CraigV is offline
Old 10-01-2009, 12:17 PM
  #9734
I heard that Associated is working on a new Buggy and a Truck....... Anyone have any info????
Murray is offline
Old 10-01-2009, 01:45 PM
  #9735
My guess would be that you heard wrong. I have heard that they're working on some updated parts, but not whole new platforms. Cool as that would be, I don't see that happening for a few years...
adam lancia is offline
