Like Tree34Likes
RC10B4/T4 Forum
Old 09-29-2009, 11:29 AM
  #9706
Tech Legend
Wild Cherry's Avatar
JDead
Try adjusting the slipper and build the diff exactly as the instructions say .
When you rebuild the diff, take care to clean off all the old grease from the gear & outdrives....
The nut for the slipper should not have to show more than 4 to 6 threads above it...
Wild Cherry is offline
Old 09-29-2009, 02:53 PM
  #9707
CClay1282's Avatar
Originally Posted by Wild Cherry View Post
JDead
+1 and also sand the diff rings with some 360 in a circular motion.
CClay1282 is offline
Old 09-29-2009, 09:21 PM
  #9708
I recently switched over to brushless and I am using a Novak Havoc ESC. The ESC rubs the bottom of the body and I am using the stock body. I was wondering if anyone knew of a body that allowed for a little more space for the ESC. Thanks for any possible help or suggestions!
agentsmith23 is offline
Old 09-29-2009, 09:34 PM
  #9709
Tony Newland's Avatar
Trader Rating: 53 (100%+)
The proline body is tall
Tony Newland is offline
Old 09-29-2009, 09:51 PM
  #9710
Which proline body? Crowd pleazer or vortex?
Old 09-29-2009, 09:53 PM
  #9711
rgrg2's Avatar
Trader Rating: 48 (100%+)
Default Body
Yes. The proline Vortex body has some extra room in that area.
rgrg2 is offline
  #9712
Deception's Avatar
Trader Rating: 24 (100%+)
The Vortex is the tallest out of the two with the side scoops....
Deception is offline
Old 09-29-2009, 09:56 PM
  #9713
Cool I was looking at that one already but it was hard to make the call just looking at pics online. Thanks for the info!
Old 09-29-2009, 11:51 PM
  #9714
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Originally Posted by jdeadman View Post
Does anyone have a tip on setting up a diff for brushless power. I keep on melting my diffs when I set them up according to AE but if I tighten it all the way I end up stripping the idler and diff gear.
I'm not an expert on the subject, but I suspect you have the diff in the wrong way. By that I mean the diff adjustment screw on the right not the left, it sounds like it is tightening itself.
I could be wrong, and I have been known to be wrong before, but something to check.
dirtdustingdavo is offline
Old 09-30-2009, 05:17 AM
  #9715
Trader Rating: 41 (100%+)
OK I may have had it wrong then. But just to confirm the adjustment screw should be on the left side (drivers side) looking from the rear of the car?
P.S. thanks for the help everyone
jdeadman is offline
Old 09-30-2009, 05:38 AM
  #9716
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
No, the diff adjusting screw goes on the right/passenger/pinion gear side of the tranny
CCristo is offline
Old 09-30-2009, 06:11 AM
  #9717
B-FAST R/C's Avatar
A bad thrust bearing can cause the diff nut to loosen or tighten.
B-FAST R/C is offline
Old 09-30-2009, 08:49 AM
  #9718
I had a bad thrust bolt cause my diff to loosen. It was brand new so I don't know if there is an issue. I put the old thrust bolt in it and the diff worked.
Alan D. is offline
Old 09-30-2009, 09:01 AM
  #9719
Alrighty I think I had it right to begin with how much slippage should the diff be doing? When I set mine up according to the manual with the transmission back together while holding the spur and one wheel, the slipper will move first but If I lock the brake I can get the diff to slip.
How much resistance should there be and how should it feel?
jdeadman is offline
Old 09-30-2009, 09:16 AM
  #9720
The way i set my diff/slipper is... tighten the diff, back it off like 1/8 turn like the manual says.... now loosen the slipper and hold both rear tires while punching the throttle.... the slipper should be adjusted where the front tires lift off the table and stay about 4" high... no higher no lower, then you can tune it further on the track, but thats typically a good place to start. My guess is your slipper is locked and its got nothing to do with the diff
