Like Tree34Likes
RC10B4/T4 Forum
Old 09-14-2009, 03:41 PM
  #9496
Trader Rating: 9 (91%+)
Originally Posted by richard.bratton View Post
If the track follows ROAR rules, he'll need to add weight with the 3800 or 5000 to reach minimum weight. I personally run the IP3800 and love it! IF ROAR isn't required, it's still best to be at minimum weight as a really light buggy is hard to handle.
Mabey your running lighter tires or wheels or mabey truck - not sure but my B4 makes weight with the reedy #709 5000mah lipo with no other added weight, plus I'm running the carbon chassis, if you run the plastic it's heavier.
msedsp is offline
Old 09-14-2009, 03:42 PM
  #9497
wayboarder's Avatar
Trader Rating: 14 (100%+)
2 weeks is far more reasonable. But every race is excessive unless you go through long periods of time between running. Ill get 2 weeks running 2 qualifiers and a main with about 1 hour or so of practice per session racing at least twice a week on a set of seals. long story short 6-7 hours of running on the seals before Ill change them for consistency's sake. But every race day? must not run very often.
Here ya go, all the tips you'll need to build a AE shocks correctly the first time.
http://users.telenet.be/elvo/12/8/1.html
wayboarder is offline
Old 09-14-2009, 04:16 PM
  #9498
RCmayor's Avatar
On the AE shocks, per an article I posted a while back, I ground the big middle spacer down from 3.3mm to 3mm. This gives the orings a little breathing room if/when they swell up a little. Also the center spacer is usually a little concave on the sides which can make it catch on the edge of the seal area on the shock body. I reduced the diameter of the round plastic pieces and this smoothed out the slightly concave plastic spacer. The diameter of all the spacers is just over 6mm when done, but an even 6mm is a good number to shoot for. I have been using the same seals for 3 weeks now and they are still butter smooth with no leaks, and this is with old non coated shafts.
RCmayor is offline
Old 09-14-2009, 04:19 PM
  #9499
rcman1993's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Michael#81 View Post
I would go with the Trinity IP3800 35C battery.
With 17.5 you do not have the power to break the wheels loose as much and the lighter weight of the 3800 will give you a bigger advantage over the heavier 5000. If you are going to go with a 5000 mah battery I would go with the Thunder Power 40C battery over any other going right now.
the thunder "chicken" doenst have as much power as the reedy. a couple of guys have them at our track and they prefer the reedy over that, the c rating is off unlike the reedy. also, i like the weight for better performance, and it doesnt matter how heavy the battery is when it has 175 amps.
rcman1993 is offline
Old 09-14-2009, 04:30 PM
  #9500
Suspended
I do it because I keeps the shocks smooth and i dont use luquid sand paper for shock oil. I also use GS Racing o rings. 20 seals perback and i bought 4 of them a month ago and still have a lot left over. IMO
RcRacer90 is offline
Old 09-14-2009, 05:50 PM
  #9501
Trader Rating: 19 (100%+)
Default camber and toe links
Is there a trick to pulling the toe and camber links off the T4? I just tore the skin off my thumb trying to get one off. They also look like they are gonna snap when Iam pulling at them.
trap121 is offline
Old 09-14-2009, 05:57 PM
  #9502
Team Turtle's Avatar
Small pair of pliers and pop them right off with a slight twist.
Team Turtle is offline
Old 09-14-2009, 05:58 PM
  #9503
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Seen a few Reedy's die lately.... one cell will loose voltage and not take a charge. Both guys are AE team drivers and know what theyre doing..... I've Been running the trinity 5000 40C's since spring with no issues so far and if they go bad I just call and they'll send another one... no BS
Tony Newland is offline
Old 09-14-2009, 06:13 PM
  #9504
Great write up. I don't know who did it but they forgot one step. Anyone who will sand .03 off of the spacers must have some thoughts on how to fill and bleed them.
DG Designs is offline
Old 09-14-2009, 06:19 PM
  #9505
Tech Legend
Wild Cherry's Avatar
Had nothing but great performance from my 5000 Reedy's for over a year now and still run great....
Have both 20C & 35C
Have not even balance um , not once...
Wild Cherry is offline
Old 09-14-2009, 06:20 PM
  #9506
You guys can really feel the difference in 17.5 offroad when it comes to C rating? I can maybe see it in TC but i dont think i could tell in offroad. Thats not what i wanted to hear about the Reedy packs. I just bought my first one. I have always run Orion and they are awesome. I bought the Reedy simply with the plan as using it for 1/8 scale some day. I cant justify $500 in batteries anymore and if i can run 2 or 3 cars with 2 packs, that works for me.
Old 09-14-2009, 06:28 PM
  #9507
Tech Legend
Default 20C verses 30C
difference is small and not really a big difference , although in stock every little bit can help...
Old 09-14-2009, 07:31 PM
  #9508
hacker's Avatar
Trader Rating: 141 (100%+)
Default diff feels crap
just building a new kit up, and the diff has been built per instructions.
all I have done different is glue the diff rings to the outdrives.
the diff feels very notchy! like it will turn 1/4 at a time, not smooth at all!
screwed it down, not even all the way down, as I was careful not to flatspot the balls.
Has anyone had any dodgy balls from the factory team kit?
hacker is offline
Old 09-14-2009, 07:33 PM
  #9509
Trader Rating: 23 (100%+)
why would you glue the rings to the outdrives?????
not home is offline
Old 09-14-2009, 07:54 PM
  #9510
Tech Legend
remove all that glue !!!
