Like Tree34Likes
RC10B4/T4 Forum
Old 09-09-2009, 12:39 PM
  #9376
Trader Rating: 20 (100%+)
Are you sure about that? I thought all FT B4s come with carbon chassis?
Guess, I have to downgrade to plastic
Originally Posted by UK.hardcore View Post
Barely anyone uses carbon, so stick with the plastic tub.
javacrazy is offline
Old 09-09-2009, 12:47 PM
  #9377
The older kits used to come with a carbon chassis but the newer black box kits come with a plastic chassis, and it really isn't downgrading to plastic because the plastic chassis provides more traction than the carbon.
Shirk is offline
Old 09-09-2009, 01:10 PM
  #9378
Thumbs up
Thanks for the answer.
Old 09-09-2009, 01:34 PM
  #9379
suparajicon's Avatar
Originally Posted by suparajicon View Post
I am a bit confused. I am now running my car with Lipos so is much lighter. The track where I run in Spain (South Europe) I think is very similar to those in California. Small track, high grip, clay with some fine dust,hard pack and not very bumpy. I have seen that thing of the 4th ,and to cut some coils in the rear black springs. But I am quite confused, is there any link to any thread or setup to have things more clear ? Thanks!
anyone?
suparajicon is offline
Old 09-09-2009, 01:44 PM
  #9380
rcman1993's Avatar
Trader Rating: 33 (100%+)
its done to gain side bite and to get more steering out from the rear. cutting the coil makes it stiffer and ives more steering in the end of the turn and the 4th hole gives more side bite for the bumby tracks. this is all done to compensate fr the lost of weight. less weight = less side bite. look on the associated website for brent theilke setup, thats the lightweight setup.
rcman1993 is offline
Old 09-09-2009, 01:48 PM
  #9381
rcman1993's Avatar
here it is.
http://67.199.85.166/racing/setups/b...crcrc_2009.pdf
Old 09-09-2009, 08:15 PM
  #9382
mandy116's Avatar
what are you gearing a T4 with a 13.5 ?
mandy116 is offline
Old 09-09-2009, 08:38 PM
  #9383
Trader Rating: 24 (100%+)
Right now im 27/75. Might go to a 26 or 28 depending on temps.
AxiomJacob is offline
Old 09-09-2009, 08:43 PM
  #9384
CClay1282's Avatar
When i run a 13.5 i run 78/24. That is with a LRP TC Spec using profile 5-8.
CClay1282 is offline
Old 09-10-2009, 01:58 AM
  #9385
Originally Posted by rcman1993 View Post
Old 09-10-2009, 05:46 AM
  #9386
We did some empirical research and came to conclusion that B4 handles best with duct taped wing and jumps best from skijump on three wheels.
The proof: http://www.youtube.com/watch?v=91qmf3sG0aU&fmt=18
AiR2k is offline
Old 09-10-2009, 06:23 AM
  #9387
Emlyn's Avatar
Anyone running a sxx with a 17.5? if so what profiles are you running?
Cheers
Emlyn
Emlyn is offline
Old 09-10-2009, 06:52 AM
  #9388
wayboarder's Avatar
Trader Rating: 14 (100%+)
Cheers
Emlyn
Punch 8, initial brake 3, drag brake 2. Timing on motor +15 degrees.
wayboarder is offline
Old 09-10-2009, 06:55 AM
  #9389
offtraxx's Avatar
Trader Rating: 59 (100%+)
any simple way of getting rid of the huge on throttle push?
running a rtr chassy with 10.5, step pins on rear, ifmar pins front, on a hard packed/ dusty track
offtraxx is offline
Old 09-10-2009, 08:05 AM
  #9390
Now don't be shy, post the rest of your setup and let's see what we can do from there
adam lancia is offline
