Like Tree34Likes
RC10B4/T4 Forum
Old 09-05-2009, 09:21 PM
  #9316
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Originally Posted by Wild Cherry View Post
UK
Spend the gears with out the top half of the gear cover .
They will push out of the pin slots rather easy correct ?
This the force Dave is refering to .....
When you put the cover back on and apply real power, this force is ampified quite a bit and as a result the gears & pins can bind against each other....
more power or torque ?
worst the problem gets .....
This why Nitro can get away with , gas motors have low torque compared to electric.....
prediction
coming soon for your 1/8th scale E ...
ball diffs !!!!
With out you will be left in the dust....
Been done years ago... BMT had an 1/8 offroad car with ball diffs.... and belt drive. Niether were durable enough.
Tony Newland is offline
Old 09-05-2009, 09:53 PM
  #9317
Tech Legend
Wild Cherry's Avatar
Default 1/8th E ball diff
Just a guess on my part , I'm assuming 1/8thE evolves into a true Electric 1/8th and not just a conversion....
Hey , I just stole some of those new blank Ae shock pistons , will report how they perform tomorrow...
Wild Cherry is offline
Old 09-05-2009, 11:22 PM
  #9318
Trader Rating: 17 (100%+)
Dont forget to drill holes
Kave is offline
Old 09-05-2009, 11:42 PM
  #9319
Tech Legend
They got marks for 4 holes on um ...
O-Man !
Old 09-06-2009, 12:19 AM
  #9320
CClay1282's Avatar
Originally Posted by Davidka View Post
Question: I got a composite chassis from a friend to replace the graphite one I have. He used shoe-goo to glue down his radio gear and it's still in the chassis, I like servo taping. Anyone know how to remove shoe-goo without damaging the chassis?
You should be able to just peel the shoe goo off the chassis. Thats what i do. May be a pain sometimes if its real thin, but it will come off.
CClay1282 is offline
Old 09-06-2009, 12:24 AM
  #9321
UK.hardcore's Avatar
in 1/8th ball diff isn't gonna happen. you need that adjustability oil gives.
Anyway in 10th i do see why ball diffs are the choice, but not for me.
I hate them.
UK.hardcore is offline
Old 09-06-2009, 12:43 AM
  #9322
CClay1282's Avatar
I hate them.
To each his own. I love em. Light and easy to build.
Old 09-06-2009, 02:41 AM
  #9323
Anyone ever weighed both diffs? T4 and SC10?
Old 09-06-2009, 07:24 AM
  #9324
Tech Legend
I don't hate or love either one , I just use the one that performs best ...
Old 09-06-2009, 07:38 AM
  #9325
porkey's Avatar
Cool
How do know that ball diffs perform best. You say gear diffs suck, and ball diffs are the way for every thing. Just wornding.
porkey is offline
Old 09-06-2009, 08:50 AM
  #9326
I can this week.... I'll have both out of the car. I'm guessing the gear diff will be heavier, but it shouldnt be by much
The Pros of the gear diff are, durability, consistency and ease of maintenence. Cons are time consuming to adjust, might be slghtly heavier.
Pros of a ball diff are, solid power delivery, simple and light. Cons needs consistent maintenence, can be tough for a newbie to get smooth long lasting service.
The Durango car is running gear diffs, That team has been on a run lately... recently winning the german nationals.....
http://www.team-durango.com/
Old 09-06-2009, 09:40 AM
  #9327
tedstryker's Avatar
Trader Rating: 86 (100%+)
so does anybody have a part#to switch my t4 to gear diff...
tedstryker is offline
Old 09-06-2009, 10:04 AM
  #9328
Tech Legend
Base Durango comes with gears , deluxe version includes ball diffs...
Old 09-06-2009, 10:10 AM
  #9329
air8's Avatar
If the ball diff is set too loose, will the vehicle lose traction AND gain traction several times quickly through corners? Basically my truck really sucked yesterday for some reason. I freshened up the diff and I don't normally suck the diff all the way down and back it off 1/8 of a turn. I get a firm feeling while turning the screw then adjust it on the track.
So assuming the diff might be a little loose, that's why I ask the question above.
air8 is offline
Old 09-06-2009, 01:22 PM
  #9330
I dont think there are different versions available? From what I've read there's only one and a rumor with no release date on the others. Looks like the car is doing fine with the current version, I would guess there will have to be a demand for any others to be produced. They have some impressive names racing/working for them now.... Adam Skelding for one, he's been Hot Bodies' designer for many years. I've heard rumors that his move has put the Hot Bodies 2w buggy in hold indefinetly.
