Like Tree34Likes
RC10B4/T4 Forum
Old 08-30-2009, 09:30 PM
  #9196
teambighead's Avatar
Originally Posted by Shirk View Post
Are you drilling the losi pistons? And what does using losi pistons change with the cars handling?
As long as you use the correct size losi pistons, you will not need to drill them.
Standard set up is to run #2 w/30wt f/r. I've started running the #55 w35 f/r. This offeres a little bit more softer static car, but due to having more holes, yet smaller holes, you will retain the pack that is needed for larger jumps.
teambighead is offline
Old 08-30-2009, 10:02 PM
  #9197
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I ran the Losi 55's in the rear today and they worked well, seemed better in the rhythm section jumps. The Losi pistons seemed a little larger diameter also but I did not measure them. How do the blanks measure up? Are they a new mold?
Cameron Kellogg is offline
Old 08-30-2009, 10:21 PM
  #9198
Cedartrack's Avatar
Trader Rating: 14 (100%+)
Default 1/2 degree hubs
Originally Posted by teambighead View Post
Here's what I'm working on currently for 2wd and truck set-ups. The set-up sheet printed weird, I'll try to fix that later tonight, sorry.
The 2wd is pretty much done. The truck is a 'work in progress'. But is very close. Either of these should be very close for most track conditions.
I forgot to put the truck pistons, front is 3-hole #57 and rear is 3 hole #55.
So have you found that the 1/2 degree hubs are unnecessary for both the b4 and T4? What advantage have you found by not using them? I have them on both and my SC10 (Scott's Setup) and they seem to work for more forward traction. But I wouldn't be able to tell the difference. Are they slower or make it harder entering or exiting corners?
Cedartrack is offline
Old 08-31-2009, 12:28 AM
  #9199
lem2's Avatar
Default Trakpower Vbalancer
Hi Guys. cycling my lipos but I forgot how the v-balancer works?
I tried looking online for a manual but no luck.
I'm using it with a silent charger. hope someone can help me.
Thanks!
Lem
lem2 is offline
Old 08-31-2009, 02:30 AM
  #9200
What would a good gearing be for a 10.5 in a B4?
terminalpvd is offline
Old 08-31-2009, 02:54 AM
  #9201
keyesgood's Avatar
Default t4 lipo
hi guys
has any one got any tips where to put weight on a t4 , with a lipo battery ip 6000 and novak 6.5 b/l gtb speedy
mk,
keyesgood is offline
Old 08-31-2009, 03:20 AM
  #9202
pink_sleeve's Avatar
Trader Rating: 185 (99%+)
http://www.comeseethis.com/gearing/gearing.htm
pink_sleeve is offline
Old 08-31-2009, 04:08 AM
  #9203
B.A. Racer's Avatar
Originally Posted by keyesgood View Post
hi guys
mk,
most people just put in on the battery itself or the battery strap
B.A. Racer is offline
Old 08-31-2009, 06:43 AM
  #9204
Tech Legend
Wild Cherry's Avatar
Keep the .5 on your Sc-10 , use the standard hub on the bug & truck.
The .5 hub performs great , its just that at TRCR the traction is so good you don't need to use....
Car will carry more corner speed with the standard hubs ...
Wild Cherry is offline
Old 08-31-2009, 07:17 AM
  #9205
porkey's Avatar
I have mine at 78/30.
porkey is offline
Old 08-31-2009, 08:44 AM
  #9206
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Mines geared at 26/78 on a 90/50 high bite track
Tony Newland is offline
Old 08-31-2009, 10:01 AM
  #9207
What up?'s Avatar
I ended up with the same oil and piston after some testing this weekend.
What up? is offline
Old 08-31-2009, 12:32 PM
  #9208
rgrg2's Avatar
Trader Rating: 48 (100%+)
Default B4
So you are saying use the #55 piston and 35w on front and rear? What type of track? And what gearing would you use at WCRC and Peg with a 17.5 novak? Thanks
rgrg2 is offline
Old 08-31-2009, 12:43 PM
  #9209
What up?'s Avatar
Yes 55s all around with 35w front and rear at peg.
I havent ran at west coast yet but I would run the same set up there and see what happens. I think West Coast would be the same just tires would be different with small adjustments.
With a Novak I would start at 69/33 and see how the temps are.
What up? is offline
Old 08-31-2009, 12:47 PM
  #9210
RCmayor's Avatar
Can the new AE shock caps and blank pistons be ordered from anywhere yet?
RCmayor is offline
