Like Tree34Likes
RC10B4/T4 Forum
Old 08-17-2009, 08:40 PM
  #8941
astroboy403's Avatar
Originally Posted by DG Designs View Post
but will it keep them from leaking? I will say the last time i rebuilt mine i used a LOT of slime and at least they are not leaking while sitting on the bench!
mine dont leak at all. so many people rag on the ae shocks being bad but in there not bad at all. if they are bad shocks then why have they won so many world titles. just my 2 cents.
also try new orings!
astroboy403 is offline
Old 08-17-2009, 08:55 PM
  #8942
Trader Rating: 14 (100%+)
They rebuild them every run! Is there a better o ring than the stock ones?
DG Designs is offline
Old 08-17-2009, 09:00 PM
  #8943
if you are having to replace the o-rings every run because they are leaking that much you might have a different problem... like to much oil in the shocks.
Old 08-17-2009, 09:07 PM
  #8944
Tech Legend
Wild Cherry's Avatar
If you have not rebuilt your shocks
and this applies to any brand, not just AE.....
two things happen ...
the seals swell
and
the shocks leak
But the worst is'nt apparent..
The word here is "striction"
Swollen seals grip the shock shafts way to tight..
The shock will not rebound all the way causing you to readjust the ride height higher & higher to get back to normal...
This makes for a lot less traction as it takes more force to initially move the shock shaft...
So you really have to rebuild often to keep that plush ride only new seals provide....
What ever you do don't use those other seals available !!!
They are way to tight and will add even more striction ..
Ae seals are the best you can buy for performance for your B-4....
Wild Cherry is offline
Old 08-17-2009, 09:26 PM
  #8945
porkey's Avatar
Originally Posted by Wild Cherry View Post
What ever you do don't buy those other seals available !!!
I run GS I rings in all of my cars and they don't grab the shock shaft. They seal it alot better then AE rings, that's all I run my my cars and won't put another AE ring in any of my cars. For 2.50 and you get 20 rings. It's a deal, have you tryed any other rings to know that they suck, I know MIP makes good ones also that are pretty close to AE rings. Try them if you like them great use them, if not them don't.
porkey is offline
Old 08-17-2009, 10:14 PM
  #8946
Tech Legend
Default Those other rings
Yes
They seal better , but smaller & too tight..
Old 08-17-2009, 10:20 PM
  #8947
vr6cj's Avatar
Trader Rating: 124 (100%+)
Yes
Green Slime helps alot with the seal and the older MIP blue o-rings where nice. Also I notice that building and hearing that click is important to sealing them
vr6cj is offline
Old 08-17-2009, 10:41 PM
  #8948
porkey's Avatar
Yes
No they are not too tight, I run them and love them. See I don't think that The red rings give the shock a good seal. IMO.
porkey is offline
Old 08-17-2009, 10:48 PM
  #8949
Tech Legend
porky
Sorry for giving you the bad news on the O-rings ....
Old 08-18-2009, 01:29 AM
  #8950
Emlyn's Avatar
+1 haven't had any of the leaking issues
Emlyn is offline
Old 08-18-2009, 08:05 AM
  #8951
porkey's Avatar
porky
Its ok but i know what you mean, AE made there rings for there shocks for a reason. I just like how long they last, they dont swell as fast, there cheap and you get 20 rings for 2.50. If i could find MIPs i would use them insted of GS.
porkey is offline
Old 08-18-2009, 10:27 AM
  #8952
ShaunMac's Avatar
I've never tried any other brand of o-ring in the AE shocks. I've never really had any reason to try something different. My shocks don't leak and stay pretty consistent between rebuilds. I don't rebuild as often as others, but I do run fresh oil every couple of race days. Dirty oil causes excess wear to pistons, shafts, bodies and the o-rings. Gritty oil is like liquid sandpaper inside the shocks and makes the shock action feel rough. Keeping fresh oil in your shocks keeps wear down and performance up.
Of course, use only AE oil in your shocks!!!
ShaunMac is offline
Old 08-18-2009, 11:05 AM
  #8953
rcman1993's Avatar
Trader Rating: 33 (100%+)
i used ae untill i saw that losi has resealable caps on their oil so i use that. It doesnt leek all over now.
rcman1993 is offline
Old 08-18-2009, 11:08 AM
  #8954
porkey's Avatar
So do you losi shock oil or just there bottle?
porkey is offline
Old 08-18-2009, 11:33 AM
  #8955
ShaunMac's Avatar
I've had a couple of the new style AE bottles leak if stored on their side. If stored upright everything stays nice and dry. Which can be tricky since the new bottles are taller than the old ones and don't fit into some containers.
I can tell you that every bottle of MuchMore oil I've had leaked like it had been shot by a BB gun.
ShaunMac is offline
