RC10B4/T4 Forum
#8808
#8810
Check to make sure the front pin brace isn't broken or cracked in any way.
My arms stopped breaking when i replaced the pin brace. (man i was cheap when i was 14 lmao)
#8814
If the motor has a big rotor in it go 81 34/35.
#8815
What are the best setups for running a T4 on a concrete oval?
#8818
Am I the only one constantly stripping out the threads in the steering idler where the servo saver bolt goes in? Have they improved this part and mabey all mine are an older version, (associated lists a part #9659 and says it replaces #9576 but does not say if why, if it fixes the issue i'm having, etc...) is this issue corrected with this new p/n. Or, should I just go buy the yeah racing aluminum steering kit or the GPM one, and if so has anyone had expierience with either one. The GPM version scares me because it eliminates the servo saver, I run a associated XP DS1015 so would that be ok?
Please help!
Thanks,
Mike
Please help!
Thanks,
Mike
