Like Tree34Likes
RC10B4/T4 Forum
Old 07-26-2009, 10:06 AM
  #8686
lem2's Avatar
Default Thanks!
Thank you for the clarification. I was just wondering it it would be read if the loop is burried slightly in the ground while being situated inside the tub.
Thanks again! Will do the suggestion.
Happy Racing!
lem2 is offline
Old 07-26-2009, 11:25 AM
  #8687
UK.hardcore's Avatar
It will read it fine.
Instead of weight on the receiver side, my RX sits where normally the speedo goes, much better left/right balance.
UK.hardcore is offline
Old 07-26-2009, 07:56 PM
  #8688
Trader Rating: 11 (92%+)
Default HELP!!!
New to racing my T4 had a few questions. how often are you guys rebuilding you shocks? Which parts do you replace when doing these rebuilds?
ive been having problems with my car nose diving off the jumps. its doesnt seem to be consistent. any tips would be great
Elies12 is offline
Old 07-26-2009, 08:07 PM
  #8689
B.A. Racer's Avatar
i dont rebuild my shcoks often but i do replace the oil every weekend after racing
B.A. Racer is offline
Old 07-26-2009, 08:58 PM
  #8690
astroboy403's Avatar
as far as rebuilding the shocks, i rebuild mine when i see a more than normal build up of oil at the bottom of the shock. a lite coat of oil is ok, but when lots of dirt and oil is at the end of the shock, ill replace all components in the shock.
what springs are you running in the front? i have golds and the work great for me.
astroboy403 is offline
Old 07-26-2009, 09:22 PM
  #8691
im running the blue springs in the front. When you replace the orange o-ring in the shock how do you snap them out?
Elies12 is offline
Old 07-26-2009, 09:37 PM
  #8692
take the shock tool and you shock with the shock shaft out from the shock. turn the shock upside down to see the hole where the shaft comes out of. then take your shock tool and with the tip of it feel the o rings in the shock. when you get to the last o ring push hard to snap the white retaining ring out of the shock. and hey presto, it comes out!
as far as the nose of the truck diving in a jump, stay on that gas boy!
Old 07-26-2009, 10:48 PM
  #8693
thanks for the tips. but i got another question... what gearing should i start with using a 17.5 bl on a medium size clay track.
Elies12 is offline
Old 07-27-2009, 12:09 AM
  #8694
CClay1282's Avatar
I run 78/28-29 on a small to medium track with a novak 17.5. I would start there and check temps after 5-6 mins.
CClay1282 is offline
Old 07-27-2009, 07:32 AM
  #8695
i was running 81/24 with lrp 17.5 and sphere spec esc. the motor get a bit hot. but not to bad. the esc and battery stay cold dont really change temp.
Elies12 is offline
Old 07-27-2009, 07:41 AM
  #8696
dmatter's Avatar
Anybody know how to get the Black Rear Springs to stop bending sideways and rubbing the shock bodies? When you compress the srings they bend sideways and catch the bodies worse then the greens.
dmatter is offline
Old 07-27-2009, 08:38 AM
  #8697
Tech Legend
Wild Cherry's Avatar
Two ways
use a belt sander and sand he top and bottom of the spring flush
#2 push a piece of silicon wire insulation over the spring where it rubs the shock body....
Wild Cherry is offline
Old 07-27-2009, 04:09 PM
  #8698
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
78/28 with a Fantom 17.5, seems to have plenty of torque and top end.
Check your spring cups are up the right way.
dirtdustingdavo is offline
Old 07-27-2009, 04:27 PM
  #8699
Ive got a Orion Vortex 17.5 and LRP Comp ESC in my B4 and i have been running a 72 Spur with a range of pinions right up to 31 without any heat problems (ive raced at least 20 times over a 5min period with similar ratios) so you can definitely go higher on the gearing, whether that will suit your track is obviously dependent on a lot of other factors and i have actually dropped back to 72/27 which suits where i race better, anyway just my two cents and give it a try, always checking temps of course as far as i can see the brushless motors need to be geared up pretty hard to get the most out of them.
mattc46 is offline
Old 07-27-2009, 06:53 PM
  #8700
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Default Reedy 5000 lipo in B4
Search is not working for me... What are folks doing to fit the Reedy 5000 pack in the B4? Thanks
Atomicsickness is offline
