Like Tree34Likes
RC10B4/T4 Forum
Old 07-07-2009, 01:43 PM
  #8521
Truck_Buster's Avatar
Trader Rating: 64 (98%+)
I just bought a T4 RTR and was wondering what you guys would recommend for replacement shocks? I would get the FT ones but I dont want to spend that much.
Truck_Buster is offline
Old 07-07-2009, 01:55 PM
  #8522
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by cjcoffroad View Post
What is a good gearing setup for a T4 with a 17.5?
We usually run 78/32 on most tracks. If its a small clay track I might drop it to 78/31 to get a little more punch.
Just really depends on your motor.
What up? is offline
Old 07-07-2009, 01:58 PM
  #8523
gregm's Avatar
Trader Rating: 57 (100%+)
There is no need to replace the stock shocks IMO. Grab a piston set, rebuild kit and green slime and keep them running smoothly.
gregm is offline
Old 07-07-2009, 03:07 PM
  #8524
I was looking for something with shock blatters really. The rtr ones dont have them.
Old 07-07-2009, 03:22 PM
  #8525
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I was looking for something with shock bladders really. The rtr ones dont have them.
Check this out.
http://order.aeteam.net/product_deta...Itemcode=31123
For the off road shocks, you just use the eyelets, retainers and bladders. On the T4 shocks I also use 2 red O rings as external limiters to prevent the piston from hitting the bladders.
SpraydbySprague is offline
Old 07-07-2009, 03:55 PM
  #8526
Thanks for the link
Alos I have some 1/4oz weights where should I put them?
Old 07-07-2009, 06:44 PM
  #8527
oldandnew's Avatar
Some of the AE guys at the track might suggest the same place you could put the losi avatar. But that's another story. Just kidding. If money is an issue IMO you could run the stock shocks for a while and then upgrade to the bladders when you need to rebuild them.
oldandnew is offline
Old 07-08-2009, 01:08 PM
  #8528
LOL well I dont stick to one brand for everything some make things better in certain areas imo
Old 07-08-2009, 02:39 PM
  #8529
Thanks for the link
1/4 oz on both sides of chassis in the rear compartment. 1 oz b/w the tranny and rear bulkhead. The AE weights fit best b/c they're square. If you use rectangular weights you'll have to squeeze them some to fit behind tranny. Would show you a pic, but that computer is down right now.
cjtamu is offline
Old 07-08-2009, 08:40 PM
  #8530
Has anyone purchased and used the Associated Complete Tuning Guide (#7468) for the T4?
If yes do you recommend it?
I searched this thread and didn't see anything. Thanks for any info.
Projected is offline
Old 07-08-2009, 08:49 PM
  #8531
carbon madness's Avatar
I have it, and it is a great aid for use at the track. Although I wish for it being called a tuning guide and the fact that you have to pay for it, that there should be more info then what the give you.
Also this is another great tuning guide and is great on covering the theroy of what changes do to the car.
http://users.telenet.be/elvo/ Also be sure to check out the set-up guide as that is a great for use at the track as well.
This link is also a good read, and is shorter to get though then the other one. It might also be a good idea to read this info first then read the other one so you have a better understanding before jumping head over heels in the other one.
http://www.rc-truckncar-tuning.com/r...on-tuning.html
carbon madness is offline
Old 07-08-2009, 10:47 PM
  #8532
I'm putting my lrp vector x-12 5.5 motor in my t4 and a sxx speed control I waill be using the stock spur gear. I was wondering if anyone can help me out with gearing suggestions? I dont know if it will get too hot using the stock pinion?
Old 07-08-2009, 11:38 PM
  #8533
Trader Rating: 20 (100%+)
Default B4 upgrades
What would be the most important upgrades to a B4. It is not a FT and is a roller with just the stock servo. I am not too worried about electronics until later, but instead which parts would be good to upgrade right away?
storytyme is offline
Old 07-09-2009, 12:15 AM
  #8534
Thanks for the info, looks like I've got some reading to do.
Old 07-09-2009, 01:52 AM
  #8535
sosidge's Avatar
I just got the e-book - a good read. Goes into a little more detail than the back of the manual about the various settings.
sosidge is offline
