Like Tree34Likes
RC10B4/T4 Forum
Old 06-16-2009, 07:28 PM
  #8236
rc10 ryan's Avatar
I ran DK's his car after the race tonight with his setup posted a few pages back. super smooth, easy to drive, hard to crash . the track is high grip carpet where foams are used. I would recommend giving it a try
rc10 ryan is offline
Old 06-17-2009, 03:31 PM
  #8237
jammincrtjames's Avatar
Does anybody have any experience with running the in-line axles?
jammincrtjames is offline
Old 06-17-2009, 03:55 PM
  #8238
porkey's Avatar
I ran them on carpet and loved them. They gave me a ton more steering and made my T4 more twicher.
porkey is offline
Old 06-17-2009, 06:08 PM
  #8239
hacker's Avatar
Trader Rating: 141 (100%+)
Default spindle height
how does spindle height affect handling?
what position do you guys use most often?
hacker is offline
Old 06-17-2009, 06:44 PM
  #8240
CClay1282's Avatar
Dont really know how it affects handling but i do know alot of setups call for middle height.
CClay1282 is offline
Old 06-17-2009, 07:23 PM
  #8241
rc10 ryan's Avatar
According to Charlie Perez on www.rc10b4.com "The "Spindles" are what your front tires attach to. You can change the height of the spindle and this mainly changes your corner exiting steering. If you need more steering as you exit the corner, you can raise the spindles (Two washers on the bottom). If you need less steering as you exit the corner, you can lower the spindles (Two washers on the top). Just make sure that you add or remove bump steering spacers as you raise or lower the spindles. This will keep your bump steer the same."
Old 06-18-2009, 04:41 AM
  #8242
bpspeed's Avatar
to make this easier, you could refer to any notes you have on 'droop'... by moving the spindles up in the castor blocks, you are reducing droop, by moving them down, you are increasing droop.
Of course I say all this assuming you have the sense to re-adjust your ride height and bump steer after you move those spacers...
if not, you just changed you droop, ride height, probably your weight bias, entry speed exit speed and ability to go back in time when you hit 88 mph
bpspeed is offline
Old 06-18-2009, 07:15 AM
  #8243
rc10 ryan's Avatar
Default 1 more thing...
you forgot the 1.21 gigawatts
Old 06-18-2009, 07:36 AM
  #8244
speedsterblade's Avatar
I got the 1.21 gigawatts but my flux capicator shorted out....
speedsterblade is offline
Old 06-18-2009, 07:49 AM
  #8245
rcman1993's Avatar
Trader Rating: 33 (100%+)
oh who needs the flux capacitor when you have that kind of power.
rcman1993 is offline
Old 06-18-2009, 11:12 AM
  #8246
Trader Rating: 87 (100%+)
You should have gotten the pro version.
MUDVAYNE is offline
Old 06-18-2009, 11:21 AM
  #8247
PartTime's Avatar
Little known secret......cut the blue and yellow wire and stick them together to get the pro levels !!
DK
PartTime is offline
Old 06-18-2009, 07:08 PM
  #8248
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Here are some AE bodies just finished up for you guys to check out...
...Jim
W.E.D.
Get Faster Gear
W.E.D.Jim is offline
Old 06-18-2009, 07:11 PM
  #8249
...Jim
W.E.D.
Get Faster Gear
Jim, I'm hoping these are my bodies!!! Are they in the mail yet?
I can't wait to mount them!!!
richard.bratton is offline
Old 06-18-2009, 07:48 PM
  #8250
W.E.D.Jim's Avatar
Richard, those are all yours in the pics(And a Slash and 8E body too not shown!)
You should have them Saturday or Monday in time for the race!
Good luck!
...Jim
W.E.D.
Get Faster Gear
