Like Tree34Likes
RC10B4/T4 Forum
Old 06-14-2009, 06:20 PM
  #8221
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
those damn shock perches, i forgot bout those. thx a ton!!! the shocks are not stickin, they behave and well actually (i know the whole moan/groan over AE shocks). i will do those test to sort out where i am. but rememberin those unlowered perches is the key. goin on my next order for sure.
thx again, keep em up front cuz you know if AE wins the worlds, the b5 will sit on cliff's shelf for another 2yrs.
R
UltegraSTI is offline
Old 06-14-2009, 08:36 PM
  #8222
rcman1993's Avatar
Trader Rating: 33 (100%+)
Originally Posted by PartTime View Post
Really glad this is not true. I regularly finish on the podium and normally have the least amount of power in the A.
DK
Thats what im trying to say, the better racer doesnt need a faster motor, like you were saying wild cherry.
rcman1993 is offline
Old 06-14-2009, 09:06 PM
  #8223
Tech Legend
Wild Cherry's Avatar
DK
I do dat one better !
by
regularly finishing in the A Mod class & my motor is`nt slow
Wild Cherry is offline
Old 06-14-2009, 09:41 PM
  #8224
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The difference between the good drivers and the slower drivers is going to be much greater in mod than in stock. Motoring up and having tons of power may gain you a tenth or so on the straight. That's not where the true driver uses the extra power. It's how they use that power in the infield and over the jumps that separates the men from the boys. That's where the second or more a lap that a good mod driver will gain over a stock racer who's running mod. Running a slower class, cutting lines does become more important, but throttle control goes out the window. And doing both is what makes a real driver. Anyone can run around the track at full throttle for most of the lap and cut corners. A real driver can handle twice the power, cut the same lines, and use the extra power coming out of and between corners and use that power to clear obstacles the slower cars can't to cut time off their laps. When you go to a track where the stock guys are running faster laps than the mod guys, those guys shouldn't be running mod. They obviously can't use that extra power and it's slowing them down. But put Pudge or Mayfield (real drivers) on that same track with a stock motor and then a mod motor, I guarantee they'll be faster with a mod.
Jon Kerr is offline
Old 06-15-2009, 07:29 AM
  #8225
CClay1282's Avatar
+1
Exactly what i was thinking, but i couldnt have said it better myself.
CClay1282 is offline
Old 06-15-2009, 08:02 AM
  #8226
rcman1993's Avatar
Obviously they will be faster since they have a faster motor, i dont care about the pros, i was talking about the joe's like us because we are not pros, so it is a little different.
Old 06-15-2009, 08:46 AM
  #8227
Tech Legend
Default Brents B-4 set-up
Dup
Old 06-15-2009, 08:50 AM
  #8228
Tech Legend
New subject !!!
I had the chance to test the new set-up posted on Rc10.com of Brents...
I found the set-up seems to be designed for very high traction conditions .
such as
wet clay .....
If you ever have to race where some are using Slicks but threads are also working ?
This set-up may be just the ticket as the Lite set-up those not perform all that well under those conditions...
At Trcr in Tacoma WA the set-up deliever a bit less traction & steering compared to the lite set-up....
Not the best for this time of the year to race with as it is dry now . In the winter when the track has a lot more moisture ?
I would think Brents set-up will perform really great ...
Old 06-15-2009, 09:09 AM
  #8229
rcman1993's Avatar
Originally Posted by Wild Cherry View Post
New subject !!!
such as
wet clay .....
Are you talking about the j concepts wave, then yes, it is designed for a wet clay track. I tried something close to this of my own on my carpet track and it did really well, just had a little oversteer with the browns so i put 40wt up front and silver springs up front. Works really well.
Old 06-16-2009, 08:21 AM
  #8230
Fishn or Racin's Avatar
Can the B4 tranny parts be used in the B2? They look identical. Also, can the B4 slipper clutch and spur be used on the B2?
Fishn or Racin is offline
Old 06-16-2009, 09:07 AM
  #8231
Tech Legend
No ....
although very smilier in appearance they are not the same...
Old 06-16-2009, 10:08 AM
  #8232
Davidka's Avatar
Trader Rating: 85 (100%+)
That setup looks a lot more like the "old" setups for nimh battery weight with the added weight in front of the transmission, front shocks to the outside of the arm. Interesting piston selections, I wonder how much of a difference those made?
Davidka is offline
Old 06-16-2009, 10:12 AM
  #8233
Tech Legend
I builted one 4 hole piston and compared it to the standard 2 hole side by side .
I found the 4 hole to be a bit softer in damping .....
Old 06-16-2009, 10:35 AM
  #8234
Trader Rating: 50 (98%+)
It is probley used for more pack. Isnt it the 4 56 holes as apposed to the #2 pistons?
micrors4guy is offline
Old 06-16-2009, 12:29 PM
  #8235
Originally Posted by TNS Racing View Post
this should settle your gearing problems. Select your car and motor then type in the spur and pinion your using and it will tell you how off you are on gearing>>>>> http://www.comeseethis.com/gearing/gearing.htm
Thanks but i have tried that and it didnt work for me, i have found a gearing that has worked for me now but it is aperently way undergeared but my system likes it so i like it
It's working now with FireFox, it was a silly Javascript issue. It also works with Google Chrome.
Email me (my address is on the page) with any suggestions or if you want me to add another vehicle.
Also, as the page states, I will be moving it soon to http://www.fastcats.ca as I won't be renewing my hosting package.
Thanks,
Craig
CraigV is offline
