Like Tree34Likes
RC10B4/T4 Forum
Old 06-11-2009, 05:32 PM
  #8161
CClay1282's Avatar
Everything graphite except for the actual chassis plate. That would be the plastic.
CClay1282 is offline
Old 06-11-2009, 06:50 PM
  #8162
rc10 ryan's Avatar
Originally Posted by Jon Kerr View Post
Brand new fresh build. Ready for her virgin run this Saturday. Just a one color wonder until I get my body in from Pound-It. I'll run it as is to start. I'm already planning on getting a full plastic set. When you guys are running plastic parts over graphite, are you running everything plastic? (Arms, chassis, front brace, towers, caster blocks, etc...?) or just the arms and the chassis?
very nice truck, should be a blast to drive
rc10 ryan is offline
Old 06-11-2009, 08:11 PM
  #8163
porkey's Avatar
Originally Posted by magnum_junior View Post
I am going to get the fatory team kit and wanted to kno whow the traxxas velineon VXL system performs in it or if I should look at something else?
Depends on what you are doing. Are you racing? Or are you bashing? If you racing then I would get a LRP, novak, or tekin. They are all sensord. And sensorless is not the best for racing. I run all novak systems in my b4 with a 10.5 and a 8.5 in my truck. If your bashing then the traxxas will be ok but the T4 is not a basher truck. It's a racer.
porkey is offline
Old 06-11-2009, 08:46 PM
  #8164
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
+1 on the sensored equipment. For a short while I ran the R1 Pro from Tekin it's their sensorless ESC. What I noticed on the track when I spun the car out in a turn ( I know, no one ever does that. ) and it rolled backwards the R1 would take a second to get the car moving again. I switched to the Tekin RS Pro and a Redline 7.5 motor and it's all good on the track.
The sensorless ESCs use feedback on the three motor wires to detect rotor position. In order for the feedback to be created, you must apply power to the motor. Hence the reason for the delay.
This delay isn't something you would notice in your backyard, but on the track it shows up on the lap times.
SpraydbySprague is offline
Old 06-11-2009, 08:49 PM
  #8165
rcman1993's Avatar
Trader Rating: 33 (100%+)
In other words, it would be a major amount of dead band, My friend had a sensorless esc and motor, i hated it. Their was no control do to large amount of dead band. And the power band was terrible, sensored all the way.
rcman1993 is offline
Old 06-11-2009, 09:45 PM
  #8166
B4 17.5
What will changing to 30wt from 35wt in the front do? beter weight transfer? more steering?
mtsb4 is offline
Old 06-11-2009, 09:53 PM
  #8167
CClay1282's Avatar
Should give a little more steering as well as faster steering response due to faster weight transfer.
Old 06-11-2009, 11:25 PM
  #8168
Tech Legend
Wild Cherry's Avatar
I really like the color Jon, nice ride....
Billy
my experience towards your question
less weight on rear bulkhead = more high speed steering +less forward bite
less weight off the chassis = more forward bite + less side bite
Attached Thumbnails RC10B4/T4 Forum-gt-2-%40-2009-hank-perry.jpg
Wild Cherry is offline
Old 06-12-2009, 01:38 AM
  #8169
What about the diferent size holes in pistons? if i have 1s in the front with 35wt oil if i change to no.2 size holes with 25wt oil?
would that be similar to no1 holes and 30wt oil?
mtsb4 is offline
Old 06-12-2009, 02:03 AM
  #8170
HanIce's Avatar
Trader Rating: 12 (93%+)
Hi fellas,
Can someone explain to me how moving the shock in or out of the shock tower affects the buggy?
Please keep the explanation rather simple...
Thanks.
HanIce is offline
Old 06-12-2009, 04:51 AM
  #8171
PartTime's Avatar
From what i have found.... #1 and 35wt, if you goto #2 with 30wt you keep the same damping but up the pack. If you drop to 25wt the pack will be the same but the damping will get softer. Damping is what you feel in the corners and pack is what you feel on landings and hard edged bumps.
Originally Posted by HanIce View Post
Hi fellas,
Thanks.
Front: inside holes will take steering away.
Rear: Inside holes take away forward bite and add side bite.
DK
PartTime is offline
Old 06-12-2009, 05:05 AM
  #8172
DK
From your experience, how does pack affect the car on small ruts?
billythekid is offline
Old 06-12-2009, 07:07 AM
  #8173
Question for those guys on brushless that consider that they have their weight distibution right.
Does the front of the car want to go up or down when in the air? forgeting about drag brake.
When i first changed to 17.5 i had the motor way back and had to add weight to the front just to stop it doing a back flip
But now that i have the smaller spur i have the motor way forward. but im still having understeer problems. its a prety high grip track
mtsb4 is offline
Old 06-12-2009, 07:31 AM
  #8174
PartTime's Avatar
Smooth type bumps or jumps is damping. Pack only comes into play with fast shock movment. Landing from a jump, small kicker jumps stuff like that. Normally ruts are a camber issue cause there in corners. A little more camber will help. Or more camber gain.
Say your running #2 30wt and the car is getting kicked around by the ruts and bumps. #1 35wt will soak the bumps up a little better but still have the balance in the corners that you had before. This is just a rule of thumb, track condistions and driver prefrents might show somthing diffrent.
hth
DK
PartTime is offline
Old 06-12-2009, 05:48 PM
  #8175
mandy116's Avatar
Trader Rating: 20 (100%+)
How are u guys gearing the B4 with the new 72t spur and a 13.5? Im currently running 31/78 with the 13.5.
mandy116 is offline
