Like Tree34Likes
RC10B4/T4 Forum
Old 06-04-2009, 05:41 PM
  #7981
mjk1210's Avatar
Originally Posted by billythekid View Post
Thanks for the suggestions. I prefer to use softer spring than messing with the ride height as that could make the car jump weird.
I don't see how raising or lowering the ride height would ever make it jump weird. Done it hundreds of times. It can be a huge difference in handling.
Put the softer spring(if u find one) on and it will jump weird and drive weird.
mjk1210 is offline
Old 06-04-2009, 07:10 PM
  #7982
BIG RE's Avatar
Trader Rating: 33 (100%+)
changing ride height on one end of the car could mess up the jumping capability
BIG RE is offline
Old 06-04-2009, 08:34 PM
  #7983
CClay1282's Avatar
Who all is going to the FTMS race this weekend? Im about 6 hours away and would like to know what time practice closes tomorrow night. Would like to drive up and get some practice in.
CClay1282 is offline
Old 06-04-2009, 08:56 PM
  #7984
chedda bob's Avatar
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 147 (100%+)
my guess would be 8 or 9 pm... biggest issue is noise w/ the generators and neighbors... come and introduce yourself!
chedda bob is offline
Old 06-04-2009, 09:39 PM
  #7985
CClay1282's Avatar
So i need a generator? lol. I dont have one.
Old 06-05-2009, 03:12 AM
  #7986
mjk1210's Avatar
Is there going to be any difference between running 4* toe in with all of it from the antisquat block or 3* there and 1* from rear hubs? Or is 4* the same handling no matter how you get it?
mjk1210 is offline
Old 06-05-2009, 03:37 AM
  #7987
Ok guys im playing around with shocks, whats a bigger step going up 5wt shock oil or going from no1 piston to no2 size piston?
Thanks heaps.
Also just gone brushless and i'v lost alot of steering (underseer) any tips.
mtsb4 is offline
Old 06-05-2009, 04:38 AM
  #7988
chedda bob's Avatar
there is a difference, but to be 100% honest.... i consider myself to be a pretty decent driver, and have ran both. didn't notice any difference from one to the other. we actually did some testing before we started pounding them out and no one else did either
Old 06-05-2009, 04:41 AM
  #7989
chedda bob's Avatar
charge off your car? or just bring an extension cord... offer someone $5 for the day and just bum power off someone. everyone out there is pretty cool especially about that. also if you pit close enough to the scoring tower and there isn't already 100 guys getting power off it you can plug into the shack.... it's limited tho.
either way come on out and have a good time
Old 06-05-2009, 04:53 AM
  #7990
Officially it's 8:00. But since camping is allowed, not sure how definite that is, as long as we don't make a racket. Like Chedda said, don't let power stop ya from airing it out at the Runn!!!
Dave H is offline
Old 06-05-2009, 04:56 AM
  #7991
Hate2Looz's Avatar
Trader Rating: 27 (97%+)
Loaded here for The Runn. I'll be there after a half day's work.
Hate2Looz is offline
Old 06-05-2009, 05:06 AM
  #7992
PartTime's Avatar
by putting the extra toe at the squat block it acts like moving your hub forward on the arm. If it were at the hub it would just add toe to help keep the rear behind the front.
hth
Thanks heaps.
You can add drag brake in the speedo to help that. But it only helps when your throttle is at neutral. Moving your rear shock outside one hole on the tower should return the steering in the middle of the corner.
hth
DK
PartTime is offline
Old 06-05-2009, 06:13 AM
  #7993
CClay1282's Avatar
Well i should be there at about 6 tonight. That way i can get in a little practice.
Would a fantom 10.5 be enough to run mod in a b4? Or is that a little on the slow side?
Old 06-05-2009, 06:19 AM
  #7994
PartTime's Avatar
Not sure what kind of driver you are but most are faster with a slower motor. The runn is pretty loamy from what I hear. I have a 6.5 in the buggy now and gona try that. If its too much then my only other opion is a 13.5. Guess gear it up and see what happens?
DK
PartTime is offline
Old 06-05-2009, 08:07 AM
  #7995
chedda bob's Avatar
should be fine, thats all i will have in both my xxx-cr and t4
ran a 6.5 in the t4 last weekend and there was absolutely no need for it... gear up the 13.5 Dennis and you will be fine
