RC10B4/T4 Forum
#7966
I want to run more leverage on the front arm (bottom of shocks at out side hole), which makes the car more stable, but I lose some off power steering. I am hoping a softer spring could help gain more off power steering into corners. Any suggestions?
#7968
#7970
Wet clay with taper pin slicks is nuts. Loads of steering and the ass to hold on to it! #1 35wt front/#2 30wt rear. Front shock outside on arm. Dialed
Half dry with barcodes. Push's pretty bad but you can step on it as hard as you want. The tail on this thing can take it.Tried #2 30wt front/#2 25wt rear. Front shock on inside hole. Did help with the steering and was just as stable as #1 piston with outside hole.
Pretty dusty (today) with barcodes. I hated the rear with the 25wt and #2's so I put a #3 back there and it drove the same but landed a ton better. Way more stable. I think Im gonna go to #2 30wt front/rear to get it better balanced. Tried a pair of taper pins AFTER the main and the car really free'd up. Stuck really good too. Guess it was too dusty for the bc? REALLY should have tried the tp BEFORE the main. Oh well. I only got beat by 6 secs
Anyway, from what Ive found out in 3 races is its all about tires, tires and tires. Pick a setup close to what you run on and then look at a few diffrent tires and inserts. Playing with the car can only tune so far. The tires have to be 90% there first. HTH
DK
#7971
Chedda,
Can you bring a 4* toe in anti squat block to pheasant run forme to pick up sat. I,m coming up from chicago to try to steal some points.
Thx.
Thx.
#7972
The other thing is to check your diff. If it's too tight it creates a push and you'll feel like the car wants to straighten out through a turn.
I would check the diff first and then adjust the ride height. Do them separately and test each separately so you know what each change did.
#7973
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 147 (100%+)
#7975
Thanks for the suggestions. I prefer to use softer spring than messing with the ride height as that could make the car jump weird.
#7976
sure will bud, come see me
#7977
BTW, its amazing what a full round on the shock actually does.
#7978
Does anyone know when the new B5 will be released?
