Like Tree34Likes
RC10B4/T4 Forum
Old 05-27-2009, 08:48 AM
  #7861
POUNDITRACING's Avatar
just put the car on it's side. The bottom tire is zero and then you can look at the top tire.
POUNDITRACING is offline
Old 05-27-2009, 02:58 PM
  #7862
Trader Rating: 27 (100%+)
i guess without pics or something of a way to do this i wont understand. Anyone wanna help me out?
C_Money is offline
Old 05-27-2009, 03:06 PM
  #7863
Krio's Avatar
Trader Rating: 159 (99%+)
Take your car and push it straight against a wall. Then grab your camber gauge, but rather than placing the base on the floor like you normally would to check the camber, rotate it 90 degrees and put it on the wall.
Krio is offline
Old 05-27-2009, 04:58 PM
  #7864
there we go, someone has answered it, thanks bud
C_Money is offline
Old 05-27-2009, 05:34 PM
  #7865
HanIce's Avatar
Trader Rating: 12 (93%+)
Hello everyone,where can I buy these .5 to 1 degree toe in rear blocks for my B4??I have been using 3 degrees standard for a while now,and want to try out these with my slightly lighter set up on my buggy...cheers.
HanIce is offline
Old 05-27-2009, 06:13 PM
  #7866
dougyunker's Avatar
Here ya go:http://www.rctech.net/forum/r-c-item...at-blocks.html
dougyunker is offline
Old 05-27-2009, 07:42 PM
  #7867
dangerwr's Avatar
Originally Posted by dougyunker View Post
Nowhere do I see a place to order. Are we supposed to PM this guy?
dangerwr is offline
Old 05-27-2009, 07:44 PM
  #7868
dangerwr's Avatar
Originally Posted by CraigM View Post
For camber, I use a spirit level application for the iphone. You calibrate it to zero against your setup board and then hold it against the tire and it tells you the camber to 0.1 degree
Uhm, no. A piece of plastic with an angle works fine.
dangerwr is offline
Old 05-27-2009, 07:54 PM
  #7869
Krio's Avatar
His first post shows his paypal addy and he instructs you to type in the paypal message box what block you would like. I personally know chedda bob and run his toe blocks on my t4 and sc10. Good stuff
Krio is offline
Old 05-27-2009, 08:25 PM
  #7870
dangerwr's Avatar
Interesting, the 1st time I went the pages did not show. Says he builds LiPo. I have a couple of packs that could be used to create one good one.
dangerwr is offline
Old 05-27-2009, 09:03 PM
  #7871
PartTime's Avatar
I tried a set of bar codes and this is what it looked liked fresh off the track. They handled pretty good. Just needs a touch more steering. Any ideas?
DK
Attached Thumbnails RC10B4/T4 Forum-picture-034.jpg
PartTime is offline
Old 05-27-2009, 09:17 PM
  #7872
Double Dee's Avatar
DK
How many minuets on them. I found that thy get better after a few heats.
Double Dee is offline
Old 05-27-2009, 09:26 PM
  #7873
PartTime's Avatar
Fresh set when I got there. two q's and main. maybe 9 total runs? They did get better but in the last min of the main the tires wouldn't hold the line.
Other than that I like them. No sauce. Just clean them up and run.
DK
PartTime is offline
Old 05-27-2009, 09:44 PM
  #7874
Double Dee's Avatar
DK
Pm sent
Old 05-27-2009, 09:45 PM
  #7875
HanIce's Avatar
Thanks doug
HanIce is offline
