Like Tree34Likes
RC10B4/T4 Forum
Old 05-26-2009, 03:34 PM
  #7846
CClay1282's Avatar
Originally Posted by C_Money View Post
Ok, so on the front I know how to adjust it using the turn buckles but how do I know when it is set at 0? What tool can i use to see?
You can nose it up against a flat wall and use your camber guage.
CClay1282 is offline
Old 05-26-2009, 04:53 PM
  #7847
Katuzo's Avatar
Katuzo is offline
Old 05-26-2009, 05:15 PM
  #7848
Gliptal's Avatar
Another way of doing it is putting the front tires over a sheet of paper and eyeballing it from above. Easier if you fold the paper so its the same width as the inside or outside of the tires.
Gliptal is offline
Old 05-26-2009, 05:38 PM
  #7849
mr crum's Avatar
rpm makes a toe gauge its around 10 bucks
mr crum is offline
Old 05-26-2009, 06:59 PM
  #7850
CClay1282's Avatar
Why do that if you already have a camber guage. plus, all i normally do is eyeball it anyway. ;-)
  #7851
Hate2Looz's Avatar
Trader Rating: 27 (97%+)
Have one and it works great.
Hate2Looz is offline
Old 05-26-2009, 07:02 PM
  #7852
Trader Rating: 50 (98%+)
I have a old toe system from when my dad used to race in the 90's. I will have to take some pics of it.
micrors4guy is offline
Old 05-26-2009, 07:15 PM
  #7853
dangerwr's Avatar
When do you take the measurement? Bones level or at rest??
dangerwr is offline
Old 05-26-2009, 09:11 PM
  #7854
POUNDITRACING's Avatar
at ride heighth.
POUNDITRACING is offline
Old 05-26-2009, 09:13 PM
  #7855
CClay1282's Avatar
Originally Posted by POUNDITRACING View Post
at ride height.
+1
Old 05-26-2009, 09:22 PM
  #7856
dangerwr's Avatar
+1
Gotcha. ThX!
dangerwr is offline
Old 05-26-2009, 11:50 PM
  #7857
Trader Rating: 27 (100%+)
I ahve the rpm toe gauge but I was looking at it and there are no degree markngs, how do you put it on the wall and use the camber gauge?
C_Money is offline
Old 05-26-2009, 11:53 PM
  #7858
CraigM's Avatar
Trader Rating: 34 (100%+)
For camber, I use a spirit level application for the iphone. You calibrate it to zero against your setup board and then hold it against the tire and it tells you the camber to 0.1 degree
CraigM is offline
Old 05-27-2009, 05:38 AM
  #7859
oldandnew's Avatar
Originally Posted by PartTime View Post
Almost got it.
RPM has a kit that has the arms and bulkhead. Then just some new pins and your good.
DK
Thanks Part Time I didn't see the page that had the bulk head with the arms for the T4. I was just looking at the GT2 page. Thanks
oldandnew is offline
Old 05-27-2009, 05:44 AM
  #7860
oldandnew's Avatar
I’m not sure if I am misunderstanding something? But can't you just hang your front tires off the front of your pit table and then use your chamber gage?
