RC10B4/T4 Forum
#7831
the b4 has shorter arms, i would suggest getting the rpm front arms, they are for the gt2 but they will work when you get the hinge pins that are for the gt2. On the label it says which ones to get. They never break, and if you break them, you can send them in to get brand new ones for free.
#7835
How exactly do i know how much toe i have? what tol is used to check this on a t4? I have the rpm gauge but it says nothing like number wise on it.
#7837
cant you adjust the front toe? Also what is the stock T4 rear set at? is it 3 degrees like you said or is it less or more?
#7838
I don't think you can purchase Rayspeed or Yokomo rear hub because no one seems to carry them anymore. So, the only readily available option is to get a custom made anti squat block with extra toe in. With this option, you may need to move the rear hub back to compensate for the shorter wheelbase. I would suggest moving the rear hub back 1 mm for every 0.5 degree of additional toe in at the anti squat bar.
#7839
Hey guys you say if I get the arms for the GT2 and change the hinge pins to the ones for the GT2. Would the new hinge pins be compatible with everything else i.e. would they be the same diameter or would this cause other changes? Thanks
#7841
Just to make sure I understand. You need to buy the Hing pins for the GT2 and yoiu also need to buy the bulk head for the GT2 if you are going to use the RPM front A arms. Thanks for the info please let me know if this is correct.
#7844
Ok, so on the front I know how to adjust it using the turn buckles but how do I know when it is set at 0? What tool can i use to see?
