RC10B4/T4 Forum
#7607
Does anyone know what is the default rear toe in on B4 and T4?
#7608
I am wondering what would be the best servo for B4 and T4.
I am currently using Futaba BLS 452 in my B4 and T4, which has 194oz of torque and 0.14s/60 degree of speed. I think my cars is rather slow at tight hair pin corners, so I am wondering if that could be caused by the slow servo speed.
Have anyone done any side by side comparison of high speed vs slow speed servo? Does it actually make much difference on how the car take corners?
#7609
Well speed abviously can make a difference... You have good 8th scale servos that you would use for steering in them.
.10 speed or under is good for 10th scales... I have BLS451's witch is 147oz in at .10 Prolly the best Futaba you can get right now.
JR servos have the best speed though. i think they have that is .06!!!! But they run big cases!
I think its 2 degree's Billy.. but I never checked before, or found out, cause the setup sheets never say on them.. lol
#7610
#7611
Really, only 2 degrees? I thought it should be more. My touring car had default of 3 degree.
#7613
#7615
Anything faster than a true .15sec is plenty quick. Not all servo manufacturers are honest with this figure so take them with a grain of salt. I use a JR 4850 (analog, 76oz/.15sec.) in my B4 and it's plenty quick.
#7616
Anyone know of a decent tire that will fit the T4 that works well on asphalt and lasts a long time, looking to spend about $20 and already have wheels...
I browsed around but wasn't exactly sure what was good.
I don't need them to race, just for play, long life is more important than grip, truck currently has a 13.5t Orion.
#7617
Have someone actually tested 0.10s vs 0.14s servo?
#7619
Ive compaired high and low speed servos in a buggy years ago. Cant remember what servos but one was .13 ish and the other was .10ish. The faster servo makes the car feel like it has more rear traction. I think mostly cause the front wheels can get in front of the rear when sliding and control it. The chassis setup is really the limiting factor of how fast or slow the car can snap around or into a corner.
HTH
DK
HTH
DK
#7620
HTH
DK
HTH
DK
did you mean the faster servo makes the car feel like it has more traction during acceleration, because you could make small correction quicker?
And the faster servo would not affect the car during cornering as much as suspension setup?
