Like Tree34Likes
RC10B4/T4 Forum
Old 04-28-2009, 03:17 PM
  #7531
POUNDITRACING's Avatar
Losi slipper setup.
POUNDITRACING is offline
Old 04-28-2009, 03:30 PM
  #7532
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by oldguyzrule View Post
The following was posted by another member here in the Northwest but some good info, gonna give it a shot for the T4 as well but he is speaking to the B4....... Most of the links dont work? but just search for that part and you will get it......
"Now that more people are using 17.5's in prep for the ECT this winter, I've had a few people asked me how to mount a smaller size spur gear onto the b4(or XXX) and retain the slipper clutch...
Obviously there is a "slipper eliminator" out there. But our cars have the slipper clutch on the car for many reasons; diff life, transmission wear, handling, and weight bias...
Below I have created a list of parts, mostly AE parts and 1 Losi part to make this conversion.
With this you should be able to run a smaller spur.
These parts you will need to acquire:
T3 Slipper Plate (outer)
http://www3.towerhobbies.com/cgi-bin...&I=LX3446&P=SM
T3 Slipper Pad
http://www3.towerhobbies.com/cgi-bin...&I=LX3447&P=SM
T3 Spur Gear Bushing
http://aedownloads.com/downloads/item_photos/6599.jpg
T3 Slipper Spring and Nut
http://aedownloads.com/downloads/item_photos/6587.jpg
T3 Spur gear screws
http://www3.towerhobbies.com/cgi-bin...?&I=LX2862&P=7
Losi Hydra Drive Spring Cup and Spring Kit
http://www.amainhobbies.com/product_...ducts_id/15126
This part you will already have-
B4 Slipper Plate (Inner)
http://www3.towerhobbies.com/cgi-bin...&I=LXEAD0&P=SM
On the Losi part A-3124. You will need to cut one end of this spacer flush, make sure you keep the side that is "keyed" the same way as the top shaft. Once this is cut you are ready to assemble the slipper clutch.
I have created a transmission blow apart drawing. This drawing shows the basic assembly of the slipper clutch.
Also shown in this drawing are the new parts used in the assembly, these have been highlighted yellow.
Here is the link for the blow apart drawing-
http://i151.photobucket.com/albums/s...5a8dd56a_o.jpg
I originally assembled and it is geared at 31/69. It seems to be pretty close for the power band. But I would recommend carrying a 30,31,32 pinion selection..."
Worth A Shot
With this you should be able to run a smaller spur to get the right fdr for your 17.5's
What up? is offline
Old 04-28-2009, 03:37 PM
  #7533
Hate2Looz's Avatar
Trader Rating: 27 (97%+)
I ran 32/75 with my 17.5 and it worked quite well. Could have easily went to a 34 tooth pinion but with the tight track that I was running it on, I didn't see the need to.
Hate2Looz is offline
Old 04-29-2009, 02:32 AM
  #7534
Great thead, im reading through it slowly. but still a little unclear about the adition of weight for a lipo setup on a b4, was it 1/2 oz at the back, and 2x 1/4 at the front behind the servo? please help.
mtsb4 is offline
Old 04-29-2009, 03:51 AM
  #7535
GWH74's Avatar
Default What Li-po fit
Hi
Will the Intellect 5000 30C Lipo fit the B4?
If not what others are people using?
GWH74 is offline
Old 04-29-2009, 04:50 AM
  #7536
Davidka's Avatar
Trader Rating: 85 (100%+)
If you're running the newer lightweight setup you only want to add weight to get the car to 1500gm. Probably best to add that weight to the battery strap or between the receiver and battery tray if you need to balance against the weight of the speed control.
Davidka is offline
Old 04-29-2009, 05:16 AM
  #7537
PartTime's Avatar
Originally Posted by GWH74 View Post
Hi
Thunder power 40c, Fantom 40c, reedy 35c, orion 3600 and 3800 will fit. Honestly, I havnt seen a lipo that wont fit. I think a buddy just got that pack and is running it in his t4.
DK
PartTime is offline
Old 04-29-2009, 08:51 AM
  #7538
Suspended
Default AE Is Killer Of All......
Originally Posted by BSchorr View Post
I like the layout...
On a side note... I noticed it was 4-20 today!
KICKING IT 420 STYLE UP THEIR THIS YEAR .COMING UP FROM SACTOWN TO CHECK HIZZIE OUT LOOKS FUN...Ae style...13.5 SS 4wd mod 2wd T mod....
losidriver70 is offline
Old 04-29-2009, 08:58 AM
  #7539
Davidka's Avatar
DK
I just got an SMC 52000/24c sport pack, it seems a little tall for the battery strap, the rear is stressed.
Davidka is offline
Old 04-29-2009, 09:41 AM
  #7540
PartTime's Avatar
Now that you mention that, a guy at the track said he filed the rear shock tower a little where the strap goes to give a little bit more hight for the pack.
DK
PartTime is offline
Old 04-30-2009, 01:30 PM
  #7541
Fishn or Racin's Avatar
Do the rear wheels for a B4 / B44 fit on a RC10 B2 / B3? I can't find any of the older Yellow B2 Rear Wheels.
Fishn or Racin is offline
Old 04-30-2009, 02:36 PM
  #7542
Not sure but I think that the offset is wider on the older rims as well as the axel size. But theat might just be for the truck.
Old 04-30-2009, 02:44 PM
  #7543
Davidka's Avatar
The B4 has different offset from all the previous AE buggies. If you use B4 rims on the older car the rim will hit stuff and the rear will be really narrow. Axle size is a little different too. You should be able to find rims through Ofna, the CRT .5 mini-truggy uses the same rims as the older AE buggy rear on all 4 wheels.
Davidka is offline
Old 04-30-2009, 02:51 PM
  #7544
Trader Rating: 22 (100%+)
Default B2/3
There is a set on ebay now. Also if you can find somewhere that sells thunder tiger they are the same as the pheonix as thunder tiger are using the old assoc mold.
Terry
Team Ash is offline
Old 04-30-2009, 03:08 PM
  #7545
Trader Rating: 50 (98%+)
If you are looking for some b2/b4 rims hit me up. I have some from my crt.5 kit in yellow that i will send you if you pay for shipping.
micrors4guy is offline
