Like Tree34Likes
RC10B4/T4 Forum
Old 04-24-2009, 04:15 PM
  #7516
porkey's Avatar
Originally Posted by micrors4guy View Post
anyone know the part number for the short black ball studs the team uses on the steering rack?
i think there 3983.
porkey is offline
Old 04-24-2009, 04:21 PM
  #7517
carbon madness's Avatar
Originally Posted by BISBEE 248 View Post
thanks to ae shocks i have to work on my car every race now also cause they always leak..
Most of the time they will leak from too much oil. Although when bulit right they will be fine for a few weeks to maybe a month and then they will start to leak slowly. Most people wouldn't even notice that they are leaking as you normaly will have to take the spring off to see if they are or not. If they are the dirt that is bulit up should be wet looking, and the dirt on the spring cups would be wet as well.
Also for racing at the local track I don't really worry about rebuliding them as I just go out there to have fun, but if I travel anywhere then I will rebulid them or put fresh oil in them depending on when I last rebulit them.
carbon madness is offline
Old 04-24-2009, 04:28 PM
  #7518
porkey's Avatar
Last seson i rebuild my shocks before every race. (one a month)
porkey is offline
Old 04-24-2009, 07:27 PM
  #7519
Trader Rating: 35 (100%+)
so what is the part number for the gs racing o rings for my b4's shocks???
comedyman809 is offline
Old 04-24-2009, 07:51 PM
  #7520
Herc Driver's Avatar
That's why I switched to Losi Shocks on my T4.
Herc Driver is offline
Old 04-24-2009, 09:51 PM
  #7521
porkey's Avatar
GSCSH10PR
porkey is offline
Old 04-24-2009, 09:55 PM
  #7522
dangerwr's Avatar
-1
dangerwr is offline
Old 04-28-2009, 11:57 AM
  #7523
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
What is the smallest spur gear you can get for the B4?? I think i have an 84 on it now, not sure though.
BSchorr is offline
Old 04-28-2009, 11:59 AM
  #7524
Trader Rating: 50 (98%+)
I wana say 75 is the lowest. I run 78/24 with a 7.5 brushless.
micrors4guy is offline
Old 04-28-2009, 12:08 PM
  #7525
BSchorr's Avatar
Well I found a Associated 72 tooth... Just wondering how far I am going to have to dremel the bulkhead to be able to move the motor far enough away to gear a 17.5 correctly for the nats. I dont typical run 17.5, only 13.5
BSchorr is offline
Old 04-28-2009, 12:16 PM
  #7526
aeRayls's Avatar
You can get way up into the 30+ pinion range with the 72. You wont need to dremel.
aeRayls is offline
Old 04-28-2009, 12:17 PM
  #7527
lbckevin's Avatar
Trader Rating: 96 (99%+)
Associated makes a 72 and 75 spur gears ...they still use the factory slipper.
lbckevin is offline
Old 04-28-2009, 12:18 PM
  #7528
BSchorr's Avatar
31/78 fits with perfect mesh. so we will see what a 72 does! im thinking 34-35
BSchorr is offline
Old 04-28-2009, 02:07 PM
  #7529
wayboarder's Avatar
Trader Rating: 14 (100%+)
im running 35/72 and can go up no problem, what I really need to liven up the 17.5 is run a 69/37. Ive seen that combo used with a 17.5 and it is just where it needs to be.
wayboarder is offline
Old 04-28-2009, 02:51 PM
  #7530
CClay1282's Avatar
Where did they get a 69 spur?
CClay1282 is offline
