RC10B4/T4 Forum
#7366
Ryan Cavaleri's setup here:http://67.199.85.166/racing/setups/t...kside_2007.pdf . The changes that I made to my taste are 4th hole in rear shock tower (have to drill extra hole on inside), 35 wt. oil in the rear, and blue springs up front. Also make sure you add weight to your car if you are running lipos. Hope this helps------------Doug
#7369
#7371
I hear you--the car does seem like it could use a little extra weight. I was a noob when I first got the T4 and was breaking all the FT stuff so I went aluminum on most everything so I am sure that added some weight! I will try the recommended FT setup first and then experiment with the Cavalieri from 2007 Trackside.
#7372
I've been looking for a light wieght set-up for a couple weeks and came up with a starting point. I would share it but I think it's a big pile of crap. I made a bunch of changes and it's getting better but I still have a long way to go. I'll be doing some more testing in the next couple weeks and will post what I know. If anyone has any suggestions that are not on any of the set-up sheets that are on AE or rc10b4's websites let me know. Making good progress but still needs work.
#7376
Hello, my B4 is finally going to be operational in the next few day, I have been gathering all the components since last fall. I am looking at the SC10 gear diff, sounds great to me, but I would like the opinion of someone who has run it. What does it take to put in in a B4?
#7377
Transmission Case for Gear Diff, PN 9826, $5.69
Complete Gear Differential SC10, PN 9827, $26.99
and maybe
Rear Motor Guard SC10, PN 9819, $5.69
Could be more parts. The prices are from Tower Hobbies, you may be able to find them cheaper elsewhere.
#7378
#7379
R/C Tech Elite Member
From what I remember, you'll need:
and maybe
and maybe
#7380
There are threads around that talk about lipo battery performance being better if it is warm. About 100f is supposed to be best. However, I wont be bothering to warm mine before a race. I do it more for the enjoyment of competing than winning. Lucky for me as I dont win often.
