RC10B4/T4 Forum
#7306
Im running a 2 cell lipo, LRP Sphere and LRP Vector 13.5. I used to run an Eraser 10.5 and LRP A.I. I was running that with a 24t pinion and the stock spur in my FT B4.
What's a good gearing, that I can gear this 13.5 up to, that will give me a similar speed as my 10.5?
a very helpful tool..
#7307
Well, right now Im running a 13.5 in my B4. Also 2c lipo, I am geared @76 (losi spur) 32 pinion. I was running @76/33 and I was right on the edge heat wise. Works well for me @ small med/hi bite track. Right around 6.00 final drive is pretty good IMO. Try it out a few laps, check heat to make sure your ballpark, and go to it man.. I'va had a lot of good drivers wheel my car and they love the power. If you have questions about gear ratio check this out- http://www.gearchart.com/index.cfm?f...n=chart.create
#7309
Hi guys, I just picked up my first off road vehicle; Its a FT T4 with a j82 conversion, speed pasion bruchless esc, novak 4300 motor. I am a TC guy by nature so this whole off road thing is new to me, if you dont mind answering a couple of questiions for me i would really appriciate it.
question 1 does any company make a conversion to allow me to use the hex mount wheels on this truck? if so who.
question 2 will i be able to use any buggy body designed to fit the B4 or do i have to stick with the J concepts brand
thankx in advance
thankx in advance
#7310
Instead of hex`s use the Ae Gt-2 quick release hub....
you can use any T-4 body made , no other buggy bodies available except JConcept...
#7311
Does anyone have a T4 Lipo setup they want to share? My truck is excessively loos and I'm trying to cure that problem. Thanks.
#7312
#7313
i geuss why i am asking about the hubs is because i have a brand new set of jaco foam tires made to fit the rustler, jato, slash exct.. but they use the hex head style mount like tc foams. i thought it would be cool to try them on the t4. we race on carpet indoor and asphault out door but if there is no way then ill just sell them because there still in the packege. thankx for the info though
#7316
Might be easyier to tune what you have instead of putting a whole new setup. Is it loose going into the turn or coming out? Moving your battery around will do alot for the handling. If its loose going in then move your pack forward. If its loose coming out of the turn, move your pack back.
HTH
DK
#7318
I now added 125 gram of lead under the LiPo, and it made a huge difference.
Also check the AE forums to find some LiPo T4 setups :aeforums.co.uk/forum/index.php?showtopic=1433
good luck and greeting from the Netherlands
