Like Tree34Likes
RC10B4/T4 Forum
Old 03-15-2009, 10:29 AM
  #7126
rcman1993's Avatar
Trader Rating: 33 (100%+)
does anyone have a setup for a indoor carpet track for the t4. I ha one tha is okay but would like one that doesnt need a massive amount ofraction compound. Im using the duratrax rubbr tires right now, not the slicks, I think they are called street force. Thanks.
rcman1993 is offline
Old 03-15-2009, 11:36 AM
  #7127
Originally Posted by MustGoFaster View Post
4wd would be the only one that may need the fan (definitly use the heat sink in 4wd though).
I test my vehicles without fans on the ESC but, if the environment you are running in is very hot (summer in AZ) you may need one. Also the amount of time you are running for will have an influence on the heat.
From your experience, would dust and dirt damage the fan if I use them in a truck (T4) or 2wd (B4) which the chassis are not sealed?
billythekid is offline
Old 03-15-2009, 01:17 PM
  #7128
dougyunker's Avatar
Originally Posted by billythekid View Post
From you experience, would the dust and dirt damage the fan if I use them in a truck (T4) or 2wd (B4) which the chassis are not sealed?
The LRP's fan seem to be very durable. I know when I used run my Novak GTB I lost a few blades (clear fan) now and then, but the blades were very thin. I don't think you would have any trouble losing blades as long as you keep the body on.
dougyunker is offline
Old 03-15-2009, 04:12 PM
  #7129
PartTime's Avatar
Im running Cavilar's (sp?) setup on mine with 2 change's. 1) 5wt heavier oil front and rear. 2) move the bottom of the shocks to the out side hole on the arms front and rear. I can run the duratrax tires with out dope but have to deal with a push for 4 or 5 laps till they heat up. The Losi tires need dope on the back. But thats also a diffrent setup.
Hit me up at the track, I can help you out.
DK
PartTime is offline
Old 03-15-2009, 04:21 PM
  #7130
gholt13's Avatar
Default gear ?
in a t4 what gears should i run with a mamba max 6900
gholt13 is offline
Old 03-15-2009, 07:32 PM
  #7131
dangerwr's Avatar
I run the stock size spur and a Robinson Racing hardened 17t pinion and life is good. I am not sure that it will work on your track but seems to be a nice "universal" setup. Cheers!
dangerwr is offline
Old 03-18-2009, 08:09 PM
  #7132
astroboy403's Avatar
well, while we are on the subject of weights in cars, i see that thelight set up for the B4 is not using the 1.5 OZ in the back of the car. what does having the weight there do and what does not having it there do? thanks.
astroboy403 is offline
Old 03-18-2009, 09:57 PM
  #7133
Tech Legend
Wild Cherry's Avatar
1.5oz was added to off-set the heavier 3800 Nk Ml packs available at the 2005 Worlds......
Wild Cherry is offline
Old 03-18-2009, 09:58 PM
  #7134
Double Dee's Avatar
[QUOTE=astroboy403;5568690]well, while we are on the subject of weights in cars, i see that thelight set up for the B4 is not using the 1.5 OZ in the back of the car. what does having the weight there do and what does not having it there do? thanks.[/QUOT.
I run B4 light set up and have had it on indoor and out doors and it ROCKS I run a novak 8.5 and have no problems with foward bight eather. I did try the light set up and left the 1.5 and it was better after it was removed.
Double Dee is offline
Old 03-18-2009, 10:00 PM
  #7135
Double Dee's Avatar
A+
Old 03-18-2009, 10:03 PM
  #7136
ok, its for forward bight. so if im at 1560 with the weight in it, taking it out will be for the better. cool thanks.
Old 03-18-2009, 10:05 PM
  #7137
Double Dee's Avatar
YES if you are runing the 4th hole in rear shock tower. you will want to lose the FAT
Old 03-18-2009, 10:07 PM
  #7138
not runing the 4th hole let but will soon. thanks again!
Old 03-18-2009, 10:12 PM
  #7139
Double Dee's Avatar
Thanks ya make shure you do the full light set up. dont miss a thing and tune only after you get a few packs in
Old 03-18-2009, 10:15 PM
  #7140
k, if you dont mind me asking, what tunes have you done to the light set up and does it work on dry blue groove tracks or is that a different set up.
