Like Tree34Likes
RC10B4/T4 Forum
Old 02-04-2009, 07:54 PM
  #6856
teambighead's Avatar
Originally Posted by Gliptal View Post
I thought I saw this on here somewhere but can't find it.
What are the factory guys using for the 1/2 degree toe on the rear carrier?
Rayspeed hubs.
Although trinity and racers edge also make them.
teambighead is offline
Old 02-06-2009, 06:33 AM
  #6857
Default t4 setup
does anybody have cavalieri/thielke T4 setup frm crcrc? post link? thanks
motorhead68 is offline
Old 02-09-2009, 05:36 AM
  #6858
mandy116's Avatar
Trader Rating: 20 (100%+)
How does the bumpsteer work? will more spacers give me more or less?
mandy116 is offline
Old 02-09-2009, 08:08 AM
  #6859
d4man's Avatar
What caster blocks?? Where is the axle?? Middle, bottom, top??
d4man is offline
Old 02-09-2009, 08:49 AM
  #6860
azgreg's Avatar
http://67.199.85.166/racing/setups/b...crcrc_2009.pdf
azgreg is offline
Old 02-09-2009, 09:04 AM
  #6861
Trader Rating: 24 (100%+)
It will make the car turn in a little harder, I usually run 1 or 2 washers.
AxiomJacob is offline
Old 02-09-2009, 09:10 AM
  #6862
DRRC's Avatar
Trader Rating: 59 (98%+)
any set ups for B4 and T4 using Lipos without weight
DRRC is offline
Old 02-09-2009, 10:15 AM
  #6863
For the b4 there is a lipo setup posted on rc10.com and for the T4 i am pretty much running the cav 06 mod nats setup.
Old 02-09-2009, 01:00 PM
  #6864
mandy116's Avatar
I am running the 30 deg blocks, axle in the middle. but no washers under the ballstud.
mandy116 is offline
Old 02-10-2009, 08:14 AM
  #6865
Dustinkeys's Avatar
Anyone know of a shop that carrys the RE or Rayspeed hubs?
Dustinkeys is offline
Old 02-10-2009, 08:33 AM
  #6866
d4man's Avatar
To keep zero bump in/out, you should have (2) .030 washers under that ballstud.
d4man is offline
Old 02-10-2009, 09:31 AM
  #6867
t4mania's Avatar
Anyone tell me the size shocks used on the FT B4 buggy front. Body size and shaft length are most important to me. Wanting to put a set on the rear of my T4 truck with a different shock tower to lower it for oval asphalt racing.
t4mania is offline
Old 02-10-2009, 09:47 AM
  #6868
d4man's Avatar
Front shock, B4: .89 body(9312), .71 shaft stroke (6418)
Rear shock, B4 1.18 body (9662), 1.02 stroke (6417)
d4man is offline
Old 02-10-2009, 12:00 PM
  #6869
t4mania's Avatar
Thanks much d4! Will the VCS2 upgrade fit these shock bodies.
t4mania is offline
Old 02-10-2009, 12:06 PM
  #6870
d4man's Avatar
Possibly...I don't do that mod..I make my own bleeder screws/caps...
d4man is offline
