RC10B4/T4 Forum
#6842
teambighead,
With the light weight setup are you not running the rear arms shaved with two spacers behind them or whatever it is?
#6843
i've got a ques for you guys that are running the lightweight set-up on the b4. i just finished installing all the electronics and battery and when i put wheels on it to set the ride height i cant seem to get enough out of it. the collars a just about maxed out. just wondering if any of you others are having this problem, and if there is a fix?!?!? thanks
http://67.199.85.166/main/productdetails.php?text=9724
#6844
i am running the black springs with 2 coils cut just as the set-up sheet 2 pages back says. rebound is a quarter inch. i am running the max-amps 5000mah lipo, which is prolly lighter than the hard case lipos. only weight i have added in is the weight in the rear which totals 1.5 oz.
Use those spring cups as I mentioned below.
With the lighter car, the weight offset of the motor has more of an effect against the weight of the car. Which is basicly what shimming the arms forward gives.
Actually, pending on the level of grip of your track, you can run your hubs further back if needed.
#6846
#6847
Flipping the collar will help also, you will gain 3/32" or so more of threading capacity.
The 1.5oz also will help bring the car up to the height you are looking for.
#6848
Thanks. They also posted the setup from CRCRC on AE's website. The setup is really close to what teambighead posted.
#6851
Give it time and try to get use to it first.
Could be a big difference from what you are use to running right now.
also
details like
radio set-up & ESC set-up are very important....
I`v been running lite for a while now and really like it...
also
details like
#6852
Anyone ever tried putting the rear hubs from the GT2 on their T4 and reversing the left and right sides for 0 toe in. Are there any other parts I would need to complete this mod.
#6853
The GT2 hubs wont work.
#6854
Yeah the gt2 hubs wont work, besides they are only 1.5* and it wouldnt get you to 0*. Your best bet is to get the racers edge 1.5's and reverse them.
#6855
I thought I saw this on here somewhere but can't find it.
What are the factory guys using for the 1/2 degree toe on the rear carrier?
