RC10B4/T4 Forum
#6782
#6783
I have been running 19 to 21 /84 with a 7.5R novak, which is 5800 kv. It would get up to around 125
#6786
#6789
#6790
t4 gearing
could someone give me idea of gearing for t4 with 10.5 on 100x60 track?
thanks
thanks
#6792
#6793
Yes, I'm using the 20c 5000's. P/N 703.
The 35c has more power, but are a are a little bit heavier. However, if you are running a spec class, such as stock or 19t, they yield more power. Most say it's like going down 1 turn. They aren't exactly needed for mod.
Keep in mind, the 709 will be a more than snug fit into the 2wd... You may have to grind to get it to fit. The 711 battery will be what you want if you get the 35c batteries.
#6794
#6795
Keys-
