Like Tree34Likes
RC10B4/T4 Forum
Old 01-22-2009, 11:33 PM
  #6766
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by teambighead View Post
In theory, they provide more forward bite, and more turn in steering.
Due to this, you are able to run a longer wheel base and keep the stability of the longer car.
Got it, thanks
What up? is offline
Old 01-23-2009, 01:46 AM
  #6767
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Originally Posted by What up? View Post
Just curious, What does this do and where do you get them if someone wants to try it?
Syber Serulean is offline
Old 01-23-2009, 10:43 AM
  #6768
BISBEE 248's Avatar
Originally Posted by AxiomJacob View Post
The AE team still useds Cavaleris 06 mod nats setup.
any idea were i can find or print this setup,switching over from losi after
many years would love the extra help thanks in advance..
BISBEE 248 is offline
Old 01-23-2009, 11:03 AM
  #6769
rc10.com, under the setups link.
071crazy is offline
Old 01-23-2009, 11:15 AM
  #6770
Double Dee's Avatar
http://67.199.85.166/racing/setups.php
Double Dee is offline
Old 01-23-2009, 11:23 AM
  #6771
Trader Rating: 83 (100%+)
Can you guys reccomend good gearing for a FT T4 with a sidewinder 5700? I am using the stock spur with a 17t pinion now but it runs on the warmer side about 140 at motor. What are the best combos?
bigbeej is offline
Old 01-23-2009, 11:54 AM
  #6772
Krio's Avatar
Trader Rating: 159 (99%+)
140 isn't bad at all and if anything you are under geared. Try a 19 or 20 tooth with the stock spur gear and watch temps.
Krio is offline
Old 01-23-2009, 12:11 PM
  #6773
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
140 is not too hot. If it were though, you could get an equal gear ratio by running a smaller pinion. Not necessary for 140 though.. I am running 20/87 w/ a 5700kV motor without any issues at all.
rearviewmirror is offline
Old 01-23-2009, 12:16 PM
  #6774
Don't know about you guys but that seems warm to me with a 17tooth pinnion.
A friend of mine was running a FT T4 with the orion system and a 19 tooth pinion and was right at 94.4*F.
Make sure that you have no binding in your drive train.
Just to make sure that you won't end up going 200*F with the 19 tooth
Alan D. is offline
Old 01-23-2009, 01:30 PM
  #6775
Krio's Avatar
The castle motors produce more torque than normal sensored motors. As such, he is over revving it and that also produces excess heat. Gear it up and the temp should drop if your drivetrain is free.
Krio is offline
Old 01-23-2009, 05:20 PM
  #6776
OHHHHHHHHHH
I get it now. Its basically like when your on the rev limiter of an old car it will over heat.
Still a good idea to check the drive train.
Like Krio said you should be fine.
i didn't know these motors made that much more torque.
Alan D. is offline
Old 01-23-2009, 05:27 PM
  #6777
When you say gear it up do you mean 18 or 19t pinion or 16 or 15t pinion? Also what is the stock FT T4 spur?
bigbeej is offline
Old 01-23-2009, 06:26 PM
  #6778
FT stock is 87.. but don't forget these were designed around brushless.... BUT, Castle still recommends a large spur with their modified motors. I am running 20/87 with a 5700kV motor and the thing is a monster.
Old 01-23-2009, 11:26 PM
  #6779
Krio's Avatar
Gearing up means a bigger pinion.
Let me clarify on the torque: Castle's sensorless motors follow a different design. They have no "stack" that the wire is wound on like novak, lrp, or orion motors. This allows for a much larger rotor for producing more torque. Having said that, it does not mean the castle motors are more powerful. Just that you need to gear them differently to find their sweet spot.
Krio is offline
Old 01-23-2009, 11:41 PM
  #6780
Trader Rating: 49 (100%+)
Originally Posted by MustGoFaster View Post
See attached file
What size and style lipo is this setup based around? 3200? 4000? 5000? hard pack?
thanks
cleblanc is offline
