Like Tree34Likes
RC10B4/T4 Forum
Old 01-14-2009, 10:22 PM
  #6676
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
The 5700 is more like a 5.5 gear it 87/22 run good batts and punch it. The c rating on the lipo makes a huge difference in the performance of the 5700 its a battery monster
chewiefttc4 is offline
Old 01-14-2009, 10:26 PM
  #6677
RCRat's Avatar
I was looking at the Cav Trackside and he runs an 87/17 w/6.5
RCRat is offline
Old 01-14-2009, 10:34 PM
  #6678
Double Dee's Avatar
Default 5700
I ran a mamba 5700 on a smll in door track clay and ran 87/17
Double Dee is offline
Old 01-14-2009, 11:06 PM
  #6679
That's undergeared. But it would probabbly be fine on a tight technical. I race here ad use a 22 www.factorytracksraceway.com
Old 01-14-2009, 11:09 PM
  #6680
RCRat's Avatar
Ok that's cool, cuz I race on a short technical AND one about your size track, so I'll pick up a 17t and a 22t.
RCRat is offline
Old 01-14-2009, 11:30 PM
  #6681
Krio's Avatar
Trader Rating: 159 (99%+)
You can't just go by KV. The castle motors (and most slotless sensorless motors for that matter) use much larger rotors than novak/lrp/trinity motors and thus produce more torque for the same KV rating. Most agree that the 5700 is close to a 6.5 or 5.5 sensored motor (or an 8 turn if you are still comparing to brushed)
Krio is offline
Old 01-15-2009, 06:18 AM
  #6682
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Originally Posted by VVRC View Post
rearviewmirror, what gear combo do you run?
I forgot my pinion size, will check in a bit. My Spur is an 87 though. I believe it's something like 18/87, but I will have to confirm.
rearviewmirror is offline
Old 01-15-2009, 06:21 AM
  #6683
I swapped trucks with a guy at my local track last night. I have a T4 w/a CC 5700kV in it, and he's got the equivalent Novak. Immediately you could tell the CC gear was so much more punchy, meaning it had heaps more torque. My T4 could wheelie down the back straight if you could keep the wheels pointed forward. The Novak really lacked punch, but it had much more driveability. So I guess if you have a smooth throttle finger there's really no limit to how fast you can go around a track with a CC 5700kV.
Old 01-15-2009, 09:40 AM
  #6684
Suspended
Talking AE.......................IS THE KILLER OF ALL!
What is in your opinions the hottest 10.5 out right now??For a B4..
Gearing 78/30-78/31 is this about the right amount...
losidriver70 is offline
Old 01-15-2009, 09:44 AM
  #6685
Tech Legend
Wild Cherry's Avatar
23 to 26 pinion /78 spur
Wild Cherry is offline
Old 01-15-2009, 11:34 AM
  #6686
You can calm down the mm put a slight curve on startup and put timing on low
Old 01-15-2009, 02:31 PM
  #6687
Suspended
+1
B4 Racer1 is offline
Old 01-15-2009, 02:55 PM
  #6688
RCRat's Avatar
Sry, for the newbie question, but what is "mm"?
RCRat is offline
Old 01-15-2009, 03:51 PM
  #6689
mamba max esc
Old 01-15-2009, 06:48 PM
  #6690
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Default T4 push
Originally Posted by adam lancia View Post
Post your setup and then we can go from there.
Current set up, working front to rear;
Front
30deg c hub
camber hole A
2 bump steer spacers
axle height up
trailing steering block
shock mount in on lower arm
position 2 on lower tower
silver spring
std shaft
5x limiters
30wt losi oil
shock in middle position on top tower (2)
Almost bones level
Rear
Med wheel base
2 deg anti sq
outer camber link position (2)
2 spacers underneath camber link
outer hole on rear hub (A)
shock on outer hole on lower arm
middle hole on shock tower
bones level
silver spring
25wt losi oil
2x limiters
additional info
No weight added
using Trakpower 5400 lipo 3/4 forward
78/32
17.5 SP
Any help to remove the push is appreciated
Darrin
dirtdustingdavo is offline
