Like Tree34Likes
RC10B4/T4 Forum
Old 12-20-2008, 03:12 PM
  #6406
Tech Legend
Wild Cherry's Avatar
Actually , the 1.5 oz weight in the back was to off-set the weight of a Nk Ml pack ...
If you use a 5000 Li-Po with no added ballast, that same 1.5 weight is not helping the car at all...
So...
Only use the extra 1.5 oz if you are running extra weight under the battery when using a 5000 Li-Po...
Wild Cherry is offline
Old 12-20-2008, 04:27 PM
  #6407
Suspended
some of us are running weight under the battery within the tray. We weight the battery and add the difference.With the above mentioned setup this does very well.
Yes, aware of that...and am doing that myself...and it does work well. What I am curious of if someone has come up with a good lightweight setup that works. Just running the truck light with some of the above mentioned setups makes it very sketchy to drive and not fast.
I guess the answer would be "just go softer and try it yourself" but I thought I'd ask around before trying to reinvent the wheel..but if nobody has tried it I think I might.
Wes Briscoe is offline
Old 12-21-2008, 06:02 AM
  #6408
Default t4 wheel question
anyone make a direct bolt on replacement wheel for the t4 in any other shape than the standard dish style? also, any one make black wheels either in standard dish style or other style? thx
blacksheep is offline
Old 12-21-2008, 12:13 PM
  #6409
aeRayls's Avatar
J concepts makes a "spoked wheel" but you need the quick change conersion for the rear. Nobody else makes a wheel. As for black wheel, RIT dye any of the wheels to get black.
aeRayls is offline
Old 12-21-2008, 01:23 PM
  #6410
carbon madness's Avatar
Doesn't RPM make wheels that fit on the T4? I don't remember off hand, but I think they do.
carbon madness is offline
Old 12-21-2008, 02:18 PM
  #6411
aeRayls's Avatar
They did make rims dont know if they still do though. They were god aweful.
aeRayls is offline
Old 12-21-2008, 04:33 PM
  #6412
Trader Rating: 19 (100%+)
any pointers/tips on rebuilding FT shocks on my T4 before i start? bought a truck second hand and raced it for 1st time today. truck did awesome!!! qual 4 in A main just want to go through shocks for next week and have never redone AE shocks before. looks like the shocks have plastic caps w/ a small screw for bleeding-possible modded???thanks in advance!!!
nitro0619 is offline
Old 12-21-2008, 07:14 PM
  #6413
Kings Kid's Avatar
Trader Rating: 35 (100%+)
post# 6379 a page back has a link that will help a bunch.
Kings Kid is offline
Old 12-21-2008, 08:57 PM
  #6414
oldguyzrule's Avatar
Trader Rating: 74 (100%+)
Maybe these....................
http://67.199.85.166/main/productdetails.php?text=7802B
oldguyzrule is offline
Old 12-21-2008, 08:58 PM
  #6415
Suspended
HPI makes a variety of wheels that come with an adapter that will make them work on almost all 2WD trucks...RPM still does make some god awful wheels, and many of them are for the T4..
I would not consider either of those wheels "race worthy" however. But if your looking for a good set of basher hoops, they work fine and some of the HPI ones look good.
Old 12-21-2008, 09:11 PM
  #6416
wow i missed that. thanks a bunch just what i was looking for
Old 12-22-2008, 12:40 PM
  #6417
Originally Posted by dmatter View Post
This is correct. Take the spacers out and measure them they are 3.20mm when new and knock them down to 2.90mm. Not as much presuure/squeezing of the O-Rings. Shocks work Better and seals last longer. Use very flat surface and TAKE YOR TIME. It's worth it.
Dax
Tried this. Still blows. There is too much coating in the channel where the snap washer sits so it just does not seat well at all. I think I have fixed the problem. I took an exhaust spring tool and filed the tip so that it is pretty sharp. I then very carefully scraped the channel with tip of the exhaust spring tool. The snap washer is now seated in the channel properly. So far it is working out well. I will not be able to track test it til Saturday.
nce71 is offline
Old 12-22-2008, 12:54 PM
  #6418
Tech Legend
Your best bet is to switch shock bodies for the rear ...
Old 12-22-2008, 04:59 PM
  #6419
trickedyfz450's Avatar
Hey guys I need some help!! I have been running my b4 ft for a little over a year now and have still not happy with the forward bite i have. I have tried lots of different things but still not helping. Please help!!!
trickedyfz450 is offline
Old 12-22-2008, 05:02 PM
  #6420
What up?'s Avatar
Trader Rating: 14 (100%+)
What set up are you currently running?
What up? is offline
