Like Tree34Likes
RC10B4/T4 Forum
Old 12-19-2008, 04:56 PM
  #6391
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by burris7555 View Post
Anybody got a good setup for a T4 running Lipo? I tried to use the search but can find anything directly... Thanks
here is a good starting point that I think alot of people run.
the only thing different that I run is silver Springs in Front and Two washers on the rear bulkhead. every track is different but it will get you really close.
http://www.teamassociated.com/racerh...kside_2007.pdf
What up? is offline
Old 12-19-2008, 05:01 PM
  #6392
Krio's Avatar
Trader Rating: 159 (99%+)
Originally Posted by CCristo View Post
25/78 will get you close
Thanks for the quick reply. I had a 6.5L the past 3 races but you just can't lay that power down on this track.
Krio is offline
Old 12-19-2008, 08:33 PM
  #6393
Trader Rating: 25 (100%+)
Sup,
I would like to know what would be a good starting point for a brushless 17.5 T4. I'm bout to order from Amain, so I would like to see where to start. The track I'll be runnin at is an indoor hard packed track w/ a 80 ft or so straight. If anybody knows the track, it's SMAC track in St. Louis. If this helps as well the tire of choice is usually Double Ds or holeshots.
thanks
Reck83 is offline
Old 12-19-2008, 09:00 PM
  #6394
Trader Rating: 17 (100%+)
Cant speak for all motors, but I ran a 17.5 LRP Vector in a T4 at smac and B&L and I liked 28/84, or 26/78 they both come out to the same ratio, depend on what gears you have, I also ran a 17.5 speed passion motor and it like alot more gearing 31/78! but 28/84 for most is a good start I think, but Im also a nitro racer most of the time
clay104 is offline
Old 12-19-2008, 09:03 PM
  #6395
Jube's Avatar
Trader Rating: 43 (100%+)
Most everything Ive read about gearing the 17.5's is that people are gearing to the freekin moon! Ive seen people saying 33,34/78 dunno personally tho just seen it several times posted.
Jube is offline
Old 12-19-2008, 09:13 PM
  #6396
clamber's Avatar
My next stadium truck will be a T4!
clamber is offline
Old 12-19-2008, 09:46 PM
  #6397
On my B4, I'm geared all the way up to 35/68 with a slipper eliminator. My motor temps only get to 98* after a 5 minute run and 102* after 7 minutes. The problem is trying to find another smaller spur that's still the right pitch.
ffejrobins30 is offline
Old 12-20-2008, 02:14 AM
  #6398
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
speedtech sells down to a 66t 48p spur gear. Will work with the turbo hub for sure.
http://www.speedtechrc.com/store/ebp...nid=392&id=957
Syber Serulean is offline
Old 12-20-2008, 07:40 AM
  #6399
burris7555's Avatar
Trader Rating: 61 (100%+)
Thanks Josh. I will give it a shot...
burris7555 is offline
Old 12-20-2008, 09:20 AM
  #6400
dmatter's Avatar
Originally Posted by LC View Post
If you sand down the big middle spacer a little this will cure the problem I know I was fighting the same problem after doing this shocks have been fine for about 3 months now.
This is correct. Take the spacers out and measure them they are 3.20mm when new and knock them down to 2.90mm. Not as much presuure/squeezing of the O-Rings. Shocks work Better and seals last longer. Use very flat surface and TAKE YOR TIME. It's worth it.
Dax
dmatter is offline
Old 12-20-2008, 10:29 AM
  #6401
Tech Legend
Wild Cherry's Avatar
The reason the seals pop out is because of a
mistake made in production .
They were suppose dip the shock in the coating then and then let it dry by standing the shock on its top .
Instead they stood the body upright, bottom down when drying the coating ...
The excess coating pooled inside where the seals go ...
Wild Cherry is offline
Old 12-20-2008, 12:46 PM
  #6402
Suspended
That's a good setup...but not really lipo specific. That setup has a 16 oz Orion NIMH pack in it... It's still a good baseline setup though.
Has anyone experimented with a no ballast lipo setup with the T4 like what Cherry posted for the B4?
Wes Briscoe is offline
Old 12-20-2008, 02:10 PM
  #6403
Kings Kid's Avatar
Trader Rating: 35 (100%+)
some of us are running weight under the battery within the tray. We weight the battery and add the difference.With the above mentioned setup this does very well.
Kings Kid is offline
Old 12-20-2008, 02:18 PM
  #6404
burris7555's Avatar
That's more of what I was wanting to know my self...
Old 12-20-2008, 02:41 PM
  #6405
carbon madness's Avatar
Just to add a little, you can do that and it is the safe way of doing things. Or if you are like me, I just add the weight (1.5oz) to the rear and go race. The biggest thing is that it is more of a feel thing, but normaly if you add weight it will be a little easier to drive the car.
carbon madness is offline
