Like Tree34Likes
RC10B4/T4 Forum
Old 12-10-2008, 02:51 PM
  #6316
Jube's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Tubaboy View Post
No offense to Murfdogg motors. But what exactly is he doing to tune a brushless motor? About the only potential that I see is 1. Testing to make sure it's not a dud. 2. Replacing the bearings with ceramics (which I doubt they're doing)
Would be interested in knowing.
Paul
I dont know what he is doing but I hear you can adjust the timing and change the performance.
Jube is offline
Old 12-10-2008, 03:11 PM
  #6317
Kings Kid's Avatar
Trader Rating: 35 (100%+)
Paul
Balance the rotor?
Kings Kid is offline
Old 12-10-2008, 03:22 PM
  #6318
What up?'s Avatar
Trader Rating: 14 (100%+)
Paul
I really havent gotten into it with him since I have just jointed the team in the last month but the things that have been talked about the most are alot of little things inside the (can) that he does that really makes a difference. If he wants to tell you him self thats fine but thats up to him.
His 17.5 was the fastest motor at the recent truck race at Hot Rod hobbies and the Nationals this year. He does alot of testing which has paid off.
I do have a Murfdogg 6.5 bl that he did that is just rediculous off the bottom end.
If you want to contact him to ask him go on the team forum and ask. His name is Matt.
http://www.rctech.net/forum/team-com...-thread-7.html
Adjusting the timeing is one thing but that is a pretty standard adjustment that helps.
What up? is offline
Old 12-10-2008, 07:19 PM
  #6319
Tech Legend
Wild Cherry's Avatar
Originally Posted by scottk View Post
I have tried that setup from wild cherry awhile back and still found the car handled better at nimh weight especially on slippery or bumpy tracks.
cheers
My own impressions after two races.....
improve balance in the turn
very predictable and easier to aim out of the turn.
extra high speed steering that the weighted car does not have and needs bad....
Traction is improved, more side bite & specially forward bite
Agree though, so far its seems a bit bumpier , not all that bad though...
Then after all that above ....
JUMPS
The jumps become easier to clear and landing`s smoother, biggest change you notice about this set-up.
Rather say for a light set-up , this one is as good as the weighted car, on par for sure...
please , not trying to shoot you down Scott . Enjoyed hearing your impressions very much...
Wild Cherry is offline
Old 12-11-2008, 07:54 AM
  #6320
Davidka's Avatar
Trader Rating: 85 (100%+)
Thanks WC, I will try that setup. On the rear camber link it calls for 1 .030 spacer on the bulkhead, can I assume that's with the newer bulkhead with the .060 built in?
Davidka is offline
Old 12-11-2008, 01:05 PM
  #6321
What up?'s Avatar
Never mind
What up? is offline
Old 12-11-2008, 02:06 PM
  #6322
tomdav's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Wild Cherry View Post
Front
Ft ball stud .060 , I`m using .090 (more = smoother steering)
30 Gt-2 Caster block , axle in the middle
Ft camber
A hole caster block & #1 on tower
Ft shock
#2 hole shock tower & I hole on arm
35W #2 piston , .030 limiter, brown spring, Thread bottom shock eyelet all the way
Rear
Drill 4th hole on tower next to hole #1
camber
rear ball stud .030 #1 hole & B hole on rear hub
rear shock
4th hole on tower, I hole on arm
30w #2 piston, silver spring .060 limiter
rear Hub forward on arm
2 anti squat
CvD`s
.060 bump steer
JConcept gold compound Bar Code ft & rear tire, 3/4 rear insert ft tire & standard insert in rear
Trinity Buggy Grip
Ft arm level & rear dogbone level
Lrp X-11 10.5 78/26
Reedy 5000 Li-Po
Lrp Competition ESC
3/16 off set motor plate ( More on this coming )
Note :
remove all ballast including 1 1/2 oz on rear
you can use 7gram on receiver side to off set ESC weight if you like
What Akerman position on steering rack, foward or rear?
tomdav is offline
Old 12-11-2008, 02:12 PM
  #6323
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
For hard pack clay ...
and a 5000 Reedy Li-Po ....
Its a brand new set-up , and not developed by me.
I stole it from a Ae factory team driver just last week end....
he got it last Tuesday...
I`v use ballast & Li-Po for years until I drove my B-4 set-up this way ....
Anyone who has`nt tried this will be thanking me next week big time....
Strongly recommend you guys try ....
News travels slow to the west coast !!!
Jason Pelletier is offline
Old 12-11-2008, 05:57 PM
  #6324
What up?'s Avatar
what up with that Five?
What up? is offline
Old 12-11-2008, 07:49 PM
  #6325
teambighead's Avatar
meh, I've had it since summer, just no time to try it...
Here's my variation of the set-up. The track that I was running on was a little slick.
http://farm4.static.flickr.com/3117/...58bdfc44_o.jpg
The standard set-up has these changes-
Front camber link shims -2
Anti Squat - 2
Rear Oil -30
Standard Rear Arm Length
Rear Hub Position -Middle
teambighead is offline
Old 12-12-2008, 01:16 AM
  #6326
t4mania's Avatar
Just picked up a FTB4 and was wondering what digital servo you recommend for the buggy.
t4mania is offline
Old 12-12-2008, 01:32 AM
  #6327
Depends on your budget and if you're going to be racing or bashing.
Racing: 150 oz/in @~.10s @6volts, metal gears.
Bashing (not my specialty but): 100oz/in @~.15s @ 6volts, metal gears if you can swing it price wise.
JR, Futaba and Hitec all make really good servos.
adam lancia is offline
Old 12-12-2008, 03:54 AM
  #6328
t4mania's Avatar
Thanks Adam I'll be racing it.
t4mania is offline
Old 12-12-2008, 05:44 AM
  #6329
Scottmisfits's Avatar
The ACE/AE 1015 or 1313, Futaba BLS451, etc. Just as Adam posted above. You don't want to fast. These things can be twitchy enough as it is. I would keep it above 0.10, better yet would be a 0.12 transit time. Not a huge difference and probably not enough to really feel. It's more of a mental thing I think.
I'm using a Futaba 9351 in mine because I had it kicking around.
Scottmisfits is offline
Old 12-12-2008, 07:40 AM
  #6330
jr9100s.... S'awesome !
