Like Tree34Likes
RC10B4/T4 Forum
Old 12-08-2008, 08:29 PM
  #6286
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Salt Lake Utah
one of the oldest tracks still around... I think we're going on 22 yrs
Home of the infamous April Fools Classic
Tony Newland is offline
Old 12-08-2008, 08:32 PM
  #6287
Jube's Avatar
Trader Rating: 43 (100%+)
Utah? Thats too far for us Michael! Looks fun though.
Jube is offline
Old 12-08-2008, 08:34 PM
  #6288
4.5 and 5.5 would be twice the HP you'd ever use in offroad... in onroad sedan traction is always available, so they can run mega HP. Even 2.5s
If you want to run mod car, I would suggest a 7.5-8.5 all the way down to a 10.5. geared right, there is very little difference in lap times.
Even consider a 13.5, a couple week ago I ran stock for the hell of it and ran within 6 seconds of mod TQ It'll all about being smooth and corner speed... straight line speed means nothing.
Old 12-08-2008, 08:36 PM
  #6289
ya that would be a bit much for a club race
but a couple guys from Indy live here now.. Cartwright and Ward, we've taken them under our wings and hold school every wed and sat night
Old 12-08-2008, 09:03 PM
  #6290
carbon madness's Avatar
The most you will ever need in a 2wd buggy is a 6.5 if you want to have an really over powered car (mostly used in trucks), then in the 2wd buggies a 7.5 would be your best best for the highest powered motor you would want to use. Although if you had a 4wd buggy then you can get away with the 5.5. Although really an 8.5 is a lot of motor.
Wow, Randy is way out west now.
carbon madness is offline
Old 12-08-2008, 11:29 PM
  #6291
Mr.Maim's Avatar
Trader Rating: 36 (100%+)
Ok, good to know and thanks for the recommendations on motors sizes, your reasons make perfect sense.
But I still have the question: Are there onroad and offroad specific brushless motors? Or can I pretty much buy any BL motor I want and slap it in a B4 and expect it to perform the same way any other BL motor would for offroad purposes?
Mr.Maim is offline
Old 12-08-2008, 11:32 PM
  #6292
no difference in motors
Old 12-09-2008, 12:04 AM
  #6293
Painy's Avatar
Can someone please send me the mod lipo setups from the 08 cactus classic.
for all three cars.. cheers.
Josh
Painy is offline
Old 12-09-2008, 07:40 AM
  #6294
Davidka's Avatar
Trader Rating: 85 (100%+)
If you run on low traction, larger tracks the "L" series motors can be good. They are like the triple wind version of BL motors. They do sacrafice total power, the 7.5L makes the same wattage as the 10.5 standard version. The 7.5 would have much more revability.
You will also find that BL motors, especailly the milder ones (8.5 through 17.5) like to be geared tall. They actually gain bottom end with taller gearing because they react well to the load. Be careful no to go too far, you will want to watch motor temps.
I run a 10.5 geared 25/81 and that's actually pretty low for that motor.
Davidka is offline
Old 12-09-2008, 09:48 AM
  #6295
Tech Legend
Wild Cherry's Avatar
If someone could please post a link for a set-up sheet I can use to post .
I`ll give you guys a B-4 set-up for no weight(52oz) & Li-Po from the Ae Team .....
Its brand new .....
Wild Cherry is offline
Old 12-09-2008, 10:10 AM
  #6296
Davidka's Avatar
I run @ 53.5 oz with about the same setup as the AE guys use with heavy stuff. My car is really fast. The biggest thing is not to over-motor it.
Here's a link, post it up.
http://www.rc10.com/racerhub/setup/B4_blank_input.pdf
Edit, I think I have the weight wrong, I believe I'm @ 55.5oz.
Davidka is offline
Old 12-09-2008, 10:17 AM
  #6297
Tech Legend
Dave , that one does not work , I need to be able to save and post ....
And you want this one Dave , it is more betta than what your using now ...
Old 12-09-2008, 10:26 AM
  #6298
d4man's Avatar
Cherry, you need a program like FoxIt Software PDF Editor
d4man is offline
Old 12-09-2008, 10:29 AM
  #6299
Tech Legend
Dang !
Here`s a taste ...
remove all weight including the 1.5oz in back
drill 4th hole on rear tower
Ft shock =35w, #2 , .030 inside, thread shock end all the way, shock in middle tower, inside on arm, Brown spring
Rear shock
25w #2 silver spring inside on arm
will post compete set-up tonight...
Old 12-09-2008, 10:34 AM
  #6300
d4man's Avatar
Posting my baseline B4 setup (testing)
File Type: pdf
d4man is offline
