RC10B4/T4 Forum
#601
HeY!!!
hey guys just to let ya know that i just tryed the graphite chassis, and some otha driver also used it, and we didnt notice a single difference in the chassis..... they felt the exact same and not twitchy. or inconsistant at all...
LaTa JoSh
LaTa JoSh
#602
in buggy you can definitely tell the difference..in truck it doesn't make much of a difference.
#603
While experiences with the plastic & carbon chasis will differ I find it interesting that if you take a look at all the pro set ups listed on www.rc10.com you won't find a set up where the pro used the carbon chasis.
#605
I run a monster in my B4.
The P2K is a good motor, but the magnets fall out somewhat easily in off-road applications. So I would stay away from it. The glue just doesn't hold up, and with all the jumps and rough tumbles, they just come loose way to often.
Run a 19-21 tooth pinion in your B4 if using the monster. I personally run a 20 on most days, a 21 tooth when the outside temp is less then 80 degrees. I run the 19 tooth pinion if the temp is extremely hot outside (Above 90-95 degrees). My motor runs to about 170 on a 95 degree day with a 20 tooth pinion.
This past weekend, it bring our last points race, and last race of the year for me, I geared up to 23 for the Main. Motor got up to 250, but no discoloration took place. Heh Last race for this motor, as I'll get new motors in the off season.
For your T4, most people I know run 17-19 pinion gears with the Monster.
Forgot to add... use purple springs on both positive and negative. Use Reedy 767 brushes.
#607
I use a 16T pinion when I race with a ROM in my T4 and it flies....Great punch and top speed...
go to www.rc10b4.com for all sorts of T4 insights....
#609
HeY!!!
Yeah i noticed that to on the website that none of them use it... or else i will run a regular monster (revenge of the monster) in both my T4, and B4.... i run on a small and kinda tight track, i'll run a 19 in B4, and a 15, or 16 on T4... or else i also ran the MIP bling cvd's and they i personally didnt notice anything, but i didnt weigh them to see if one is lighter then the otha.(imo i just think its more of a bling factor) but they are nice.
#611
I have moved onto a new project and that is building the dream stock racing T4. I will race it in the upcoming US Central Electric Point Series on Oct 15th at Speed Racer's Hobby Shop in Richardson, TX. So far here is what I have:
- Factory Team T4 Kit
- Quantum 2 ESC
- Airtronics 94452 Servo
- Spektrum Receiver
- AMB Personal Transponder
- Team Brood Blue Printed P2K2 Motor
- Fusion Power 3700 1.90+ 450+ direct solder batteries
- Downgraded to the Composite/Plastic Chasis
- Yokomo Bleedable Shock Caps
- Lunsford Quick Tune Titanium Shock Mounts
- Battery Strap Thumbscrews
- Trinity Light Weight Slipper Plates
- Lunsford Titanium Screw Kit
- Lunsford Titanium Turnbuckle & Hinge Pin Kit
- RPM Front Bumper
- RPM Gear Cover
- RPM Ball Cups
NOTE: I know the T4 is a great kit and is a top performer out of the box and some of these items will add barely noticeable performance gains, the point is if money were no object what would be the dream stock machine
- Quantum 2 ESC
- Spektrum Receiver
- RPM Front Bumper
- RPM Gear Cover
- RPM Ball Cups
#612
Avoid the RPM ball cups completely, i dont think they are any stronger. Use either the stock associated, or the losi hd plastic ones.
#613
I've been running RPM ball cups on my T4 ever since I got it, and have never had a problem with them. Plus they look better.
#614
Originally Posted by jamescam
Anyone know how avid rc bearings compare to the bearings you get in the Factory Kit?
Peace Aaron(W-W)
#615
- RPM Front Bumper
- RPM Gear Cover
- RPM Gear Cover
