RC10B4/T4 Forum
#6076
whats the part number for the limiter shims that go in the shocks?
#6078
On limiters, what is the effect of reducing droop on the rear of the car? I had a problem with popping dog bones for a while, so added a few limiters to reduce the droop.
Fixed the dogs popping, but i'm not really experienced enough on the trackto know if it's having an adverse effect elsewhere. I don't really want to unnecessarily lose performance because of an annoyance!
#6080
#6082
T4 running lipo, where are guys adding weight on the truck?
#6083
1oz under tranny
.25oz in rear side pods (behind esc, behind rx)
the rest under the battery.
*the rest=whatever it takes to get up to I dunno...65+/-oz at race-weight.
I don't run a truck so I don't know the overall weight yall are using, but I know a heavy car is a happy car.
#6085
Location: Queensland, Australia, Earth, Galaxy, Universe, A Childs Sandpit
Trader Rating: 42 (100%+)
Hey guys. This might sound like a stupid question ,but with this front wheel mod, what front wheels do you use from the LOSI range? And what are the names of those skinny front B4 tire that I see everyone using. ( with the 4 grooves )..I've been running a B44 since they came out and only just got a TF B4 this week. I got it used and it only has LOSI taper pins on some stock B4 rims.
http://www.rc10b4.com/forum/showthre...ight=bk2+front
#6087
#6089
#6090
http://www.users.bigpond.net.au/bigfix/
So i would use the narrow/standard 4 rib part# 8175 tires yeah? So will these tires fit on those LOSA7004 Wide wheels still or is there a narrow/standard wheel that suits? I see the wide wheel is the same width as my B44 front wheels. I owned a XXX4G+ and noticed that if i swapped the front LOSI hex spacer over with a Associated hex spacer (the associated one being a thicker spacer because the associated front wheels have a deeper hex hole in the wheel (and if you just tried to fit an associated front wheel on the LOSI hex you would 1):have a wider offset and 2):run the risk of the hex pin coming out as it is not protected by the wheel)) that I could run B44 wheels all round and I would only need to have one make of wheels in my pit box. If these LOSI wheels that i am to use with the wheel MOD are the same width as the B44 wheels can I use my B44 wheels all round after changing to the Associated hex? Then I can run my Rulux wheels
Thanks for all the help lads...Oh and I am
