Like Tree34Likes
RC10B4/T4 Forum
Old 11-16-2008, 01:03 PM
  #6016
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
the slipper peg kimbrough spur gear combo...
worked a little for me. It was would slip but catch enough to work well. After 3 runs, it was gone and would slip under the slightest throttle. The plates are hitting some part of the plastic flanging still...or something. Im likely going to get a sanding disk and flatten each side of the spur a little more to see if that'll help.
Otherwise im at a loss. I may try the t3 slipper setup.
Syber Serulean is offline
Old 11-16-2008, 04:33 PM
  #6017
carbon madness's Avatar
Originally Posted by mandy116 View Post
Whats the correct rear silver spring for the B4? A main hobbies shoes two different springs with different numbers
Do you want front or rear springs? The rears are softer sprung the the fronts, and they are the same springs used on the 10th scale trucks rear spring. The fronts are short, and have a stiffer spring rate then the rears.
carbon madness is offline
Old 11-16-2008, 07:45 PM
  #6018
mandy116's Avatar
Trader Rating: 20 (100%+)
I need the rear springs, AE has two silver rear springs with different part numbers but they dont specify which one is which
mandy116 is offline
Old 11-16-2008, 07:51 PM
  #6019
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
asc21201 and asc6478
asc21201 is an RC18t spring
CCristo is offline
Old 11-17-2008, 08:57 AM
  #6020
d4man's Avatar
Does the new FT T4 kit come with a plastic chassis like the newer FT B4 kit??
d4man is offline
Old 11-17-2008, 09:07 AM
  #6021
badassrevo's Avatar
yes
badassrevo is offline
Old 11-17-2008, 10:40 AM
  #6022
d4man's Avatar
Thanks badassrevo!
d4man is offline
Old 11-17-2008, 06:29 PM
  #6023
mandy116's Avatar
thanx homie
mandy116 is offline
Old 11-17-2008, 07:32 PM
  #6024
jamminnay's Avatar
man i did not even know they were coming with plastic chassis now.. that a good thing. i always hated buying a new car then a new chassis to go with it
jamminnay is offline
Old 11-17-2008, 08:47 PM
  #6025
d4man's Avatar
I wanted to avoid doing that if it isn't needed. I'll buy B44 hub carriers and the battery thumbscrews instead...
d4man is offline
Old 11-17-2008, 09:02 PM
  #6026
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Anyone sell these in the USA?
Its a brass anti-squat mount from Trishbits in the UK
Attached Thumbnails RC10B4/T4 Forum-oop_9157.jpg
Tony Newland is offline
Old 11-17-2008, 09:06 PM
  #6027
Oh wow, i could use one of those. how much does that weigh? Equivalent to adding the 1 oz. back there?
Tater salad is offline
Old 11-17-2008, 09:07 PM
  #6028
28.5g
just over an ounce
Old 11-17-2008, 09:32 PM
  #6029
perfect, where can they be bought?
Old 11-17-2008, 09:49 PM
  #6030
Michael#81's Avatar
Trader Rating: 271 (100%+)
[email protected]
Email him and he should be able to hook you up.
Michael#81 is offline
