Like Tree34Likes
RC10B4/T4 Forum
Old 10-31-2008, 11:28 AM
  #5911
aeRayls's Avatar
Guys guys guys, first he only asked about a B4 shiny cvd's not B44. The mip kit states for RTR B4 for whatever reason, but it can be used with any B4 of course.
aeRayls is offline
Old 10-31-2008, 11:46 AM
  #5912
midwestcajun's Avatar
Could someone please tell me a good setup to have on your ESC (setting up on computer)...punch power etc for a high grip technical track with a lot of jumps that need quick power and not a ton of top speed...I have a 5700 motor with MM ESC. Im also only running Orion 3000 NiMah batts....18 pinion with stock spur gear...and suggestions on changes? would Lipo make a huge diff on power? Thanks in advance for any help.
midwestcajun is offline
Old 10-31-2008, 12:06 PM
  #5913
Company Representative
SweepRacingUSA's Avatar
Originally Posted by cjtamu View Post
Not quite sure we're on the same page. AE 9763 is the center CVA shaft for the B44, so 9763 is obviously not the same part as the MIP 1550. AE 9754 is the rear bone for the B44, AE 9597 is the bone for the B4, so obviously not the same part either. My guess is that the MIP 1550 is the equivalent of the AE 9597 (B4 bone), just shinier LOL.
nope,I wrote 9673 not an 9763 I do beilive that is same bones, BTW I can't find the coach's comment. can you have the link?
SweepRacingUSA is offline
Old 10-31-2008, 02:50 PM
  #5914
R/C Tech Elite Member
DavidR's Avatar
Trader Rating: 97 (100%+)
Hey guys... I'm back!
I just ordered the following parts for my new T4 FT Kit - I'm gonna build it once and forget about it!
You guys see anything I missed? Or anything that I should consider changing?
Ohhh BTW this will be a Lipo powered truck.. Thus all the aluminum trying to get the weight back up.
Thanx!
Team Associated
9577 Steering Blocks*
6439 Blue Hard Anodized Shock Cap x 4
7459 Aluminum Inline Axle*
9635 Rear Sway Bar Kit
1105 Green Slime Shock O-Ring Lube
1787 Factory Team Battery Strap Thumb Screws
1734 Factory Team Body Clips
1766 Lightweight Outdrive Set
1777 Shock Pivot Ball
1780 Shock Bushing
9787 Chassis Protective Film
Lunsford
7109 Long Broach 1/10th Scale Ball Studs
7901 Fat Boy Short Motor Screws
14014 RC10T4 Super Duty Plus Combo Kit - 3.5mm TBuckles and Hingepins
K-Factory
K1503B Blue Alu. Rear Hub Carrier w/ Carbon Camber Plates
K1501B Blue Alu. Steering Blocks and Hardened Shaft*
K1509B Blue Alu. Steering Rack
K1505B Blue Alu. Front Bulkhead
K1508 Carbon Steering Brace
K1511B Blue Alu. Rear Brace
K1514B Front Shock Tower
K1515B Rear Shock Tower
K1517B Carbon Battery Strap w/ Blue Aluminum Heatsink
ACER Racing
N007 (12) 3/32 Ceramic Diff Balls
N006 (8) 5/64 Ceramic Diff Balls
CA004 Ceramic Pro Series Bearing Set
Outerwears
44-2293 1/10 Scale Shock Outerwears – Flame Evolution
RPM
80082 Black Spur Gear Cover 5.99 MSRP
MIP
LXCC25 MIP Shiny Dogbones
DavidR is offline
Old 10-31-2008, 03:15 PM
  #5915
ddd228's Avatar
Trader Rating: 24 (100%+)
Thanx!
Team Associated
1780 Shock Bushing
Lunsford
K-Factory
ACER Racing
Outerwears
44-2293 1/10 Scale Shock Outerwears Flame Evolution
RPM
MIP
While you were at Kfactory why not pick up the motor heat sink? Works well but not with Lunsford fat boys.Use the stock motor plate. I had leak problems with the blue shock tops.
ddd228 is offline
Old 10-31-2008, 03:17 PM
  #5916
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
You don't need all that crap.
Jason Pelletier is offline
Old 10-31-2008, 03:21 PM
  #5917
lbckevin's Avatar
Trader Rating: 96 (99%+)
Why would you waste your money on the K factory alum. parts ??????
The stock setup is great. The lightweight outdrives, dont do well with brushless power, they snap.
Save money and get a lipo and a good charger, dont waste it on eye candy and then your truck will bend and tweak and you wont even notice.
lbckevin is offline
Old 10-31-2008, 03:30 PM
  #5918
Tech Legend
Wild Cherry's Avatar
[QUOTE=DavidR;5000785]Hey guys... I'm back!
Most of the parts you show are not required for the best performance...
specially
1734,1777,1780
6439
9635
1766
7109
7901
14014
all the K parts
acers parts
rpm cover
mip dogbones
Wild Cherry is offline
Old 10-31-2008, 03:33 PM
  #5919
TorchAZ's Avatar
Trader Rating: 12 (93%+)
Talking
What about a JConcepts T4 Illuzion body?
TorchAZ is offline
Old 10-31-2008, 03:35 PM
  #5920
Tech Legend
ok
(JConcept)
although stock body perform great as well....
Old 10-31-2008, 03:43 PM
  #5921
TorchAZ's Avatar
Oh were we basing this on performance? Cuz it seemed he wanted a pretty lookin T4.
Nonetheless, the Illuzion body is much better looking in my opinion. But you are right, the stock T4 body will work just fine. But if he is spending all this money for stuff he really doesn't need then why not spend an extra $20 to get a better lookin body?
TorchAZ is offline
Old 10-31-2008, 03:44 PM
  #5922
idbdoug's Avatar
Trader Rating: 38 (100%+)
For the price difference it definitely is not worth it. I got one and its okay but going back to stock body on the next paint job
idbdoug
idbdoug is offline
Old 10-31-2008, 03:53 PM
  #5923
TorchAZ's Avatar
Smile
Doug,
You are probably right. I don't even have a T4. I was just throwin out my 2 cents worth.
TorchAZ is offline
Old 10-31-2008, 04:02 PM
  #5924
DavidR's Avatar
LOL... OK Guys so maybe there is alot of eye candy there. But at the same time I needed to put some weight back in the truck because of running Lipo. The majority of the parts I chose keep the weight fairly low on the chassis... And Yeah... They look awesome.
Yeah.. I could have done it with plates under the battery.. but what fun is that? I want this thing to look awesome as well as perform awesome.
Money really isn't an issue... So yeah! I'm gonna blow a little on this thing.
I just figured maybe you guys would have some ideas on some more stuff that would actually effect the way the truck drives or something to help the durability.
But I see that for the most part everybody wants to bash my choices in spending cash that I bust my ass for every day. So maybe I'll just keep my posts to myself from now on.
I do appreciate the post regarding the lightweight outdrives... I am running a Novak GTB Spread Spectrum with a 13.5 Brushless motor. I don't really think breaking those under what is essentially a stock motor will be a problem. But thanks for the heads up anyway. I truly do appreciate an honest response instead of just bashing my choices.
BTW - Yeah.. I did buy the JConcepts Hi-Flow Illuzion Body. Was actually one of the first things on my list... That thing is awesome looking!
But thanx anyway though.
DavidR is offline
Old 10-31-2008, 04:03 PM
  #5925
TorchAZ's Avatar
Post
Hey I actually have a question about lipos if anyone can help me...
Can I use a lipo battery without buying a brushless esc and motor or can I use it with my existing setup?
Right now I have a LRP Quantum 2 esc with a 19t Checkpoint Money motor.
I was planning on buying an Orion 3800 lipo but wasn't sure. I don't want to fry anything!
TorchAZ is offline
