Like Tree34Likes
RC10B4/T4 Forum
Old 10-28-2008, 04:16 PM
  #5881
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Originally Posted by dangerwr View Post
I believe they are the outer hinge pin set for an Associated GT2. I bought mine on eBay and the Team Associated P/N is 7927. I have spent quite a bit of $$ to make my T4 handle the punishment due from the MM.
I would also recommend, as a friendly gesture, investing in one of those SS screw kits for the T4. Mine was made by RC Screwz and has played a tremendous role keeping the truck together.
Have fun for they are a blast!!!
You do realise that ss is softer than the kit screws. The kit hardened steel screws should be kept in high stress areas for the most durability.
chewiefttc4 is offline
Old 10-29-2008, 11:52 AM
  #5882
Company Representative
SweepRacingUSA's Avatar
agreed
my used JRXS-TypeR came with that stainless steel screw set and they are softer and also I found out all that button head screwz hex is too big (button head is fine), my 0.063 tool keep stripping those and I had to repace all of them back to stock screws.
bone stock WTG~
SweepRacingUSA is offline
Old 10-29-2008, 12:41 PM
  #5883
Trader Rating: 53 (100%+)
Does the T4 come with metric or standard scresw?
underway is offline
Old 10-29-2008, 12:53 PM
  #5884
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Standard
Jason Pelletier is offline
Old 10-29-2008, 07:13 PM
  #5885
dangerwr's Avatar
Maybe the SS kits are not hardened but have never broken any of those--unlike the kit screws. Harder is not always better when shear is involved in the equation .
Hard to buy the kit screws too, right? Have never seen them . . .
dangerwr is offline
Old 10-29-2008, 07:17 PM
  #5886
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
http://www.tonysscrews.com Best screw kits
CCristo is offline
Old 10-29-2008, 07:22 PM
  #5887
air8's Avatar
+1 to Tonys Screws.
air8 is offline
Old 10-29-2008, 08:22 PM
  #5888
the tony screw kits are standard also?
underway is offline
Old 10-29-2008, 08:42 PM
  #5889
air8's Avatar
yes they are.
air8 is offline
Old 10-29-2008, 11:50 PM
  #5890
ddd228's Avatar
Trader Rating: 24 (100%+)
Default CARPET?
Originally Posted by Red Z View Post
I tried them. They fit. YAY! Anyone race B/T -3 or -4 on carpet tracks with foam tires?
Sorry to reply on this old post but YESSSSSS!!!! i been there!!! 3 seasons. I know what breaks and how to jump,etc.
ddd228 is offline
Old 10-29-2008, 11:56 PM
  #5891
ddd228's Avatar
Wink NOVAK question
Originally Posted by Wild Cherry View Post
Snap a wing shim in half and glue behind the wing mount....
tilts the wing more and developes
extra down force....
Please excuse me for not asking about your wing mount..It's a Novak BL motor question,if you don't mind: What is the part called that the 3 wires are soldered on the black plastic plate? End bell end piece?Mine is cracked. Thanks George.
ddd228 is offline
Old 10-30-2008, 12:10 AM
  #5892
DavidR's Avatar
Trader Rating: 97 (100%+)
Hey Folks...
I'm looking to build a new FT T4 Kit and am looking to upgrade some things as I go.
What all can I do to the transmission assembly besides Ceramic Diff Balls and bearing to maximize efficiency.
I've already got lightweight outdrives as well..
I've heard talk about Trinity Lightweight Clutch Plates but can't find them anywhere... Anybody got a source or part number?
Thanx!
DavidR is offline
Old 10-30-2008, 07:12 AM
  #5893
If you're building a new FT T4 I assume you're going to put BL and possibly LiPo power into it. The truth is you don't need lightened outdrives, clutch plates, etc. 'cause we all have too much power anyway. Unless you're racing Stock where you're trying to reduce every gram of rotating weight yeah okay, but for Mod I don't worry about it. The best thing you can do to a T4 is make sure your wheel bearings and hub carrier bearings are clean and well maintained. I clean the grease out of mine and run bearing oil. More maintenance but smoother rolling. The only thing I do to the diff is sand the rings with 600 grit sandpaper. Removes the flat spots and adds a little texture to the rings. Make sure there's no binding in the suspension, ream the parts a little if you have to. Add 1 1/2 oz of weight to the rear when you build it and you're good to go.
cjtamu is offline
Old 10-30-2008, 09:52 AM
  #5894
Tubaboy's Avatar
Yeah Ceramic bearings aren't really necessary. I put them in my car, and honestly, it didn't make a difference. I still have to service the diff the same amount.
Really add the weights as shown elsewhere in this thread. The kit bearings aren't the best for the rear hubs. perhaps upgrade to the B44 rear hubs, or the Quick Hub Change (Not sure that uses a different size bearing though).
Check your arms to make sure that the hinge pins rotate freely. I always have to reem out mine as they tend to bind.
PB
Tubaboy is offline
Old 10-30-2008, 10:21 AM
  #5895
Suspended
Thumbs up AE.......................IS THE KILLER OF ALL!
? anybody ever have a front caster hinge pin come through the front of the front arm??
losidriver70 is offline
