Like Tree34Likes
RC10B4/T4 Forum
Old 08-31-2005, 01:34 AM
  #571
jamescam's Avatar
Originally Posted by colinradford
Don't use the stainless steel screws for mounting the shocks, they will bend. Should be fine everywhere else, I like the bling too!
One other hop up I forgot to mention that I already had sitting in my box is the Lunsford Quick Tune Titanium Shock Mounts. More durable and easier to change!
jamescam is offline
Old 08-31-2005, 06:32 AM
  #572
nwilcox88's Avatar
Let me see if I have this correct, go with Stainless Screws and with lightweight slipper plates. If weight is the real concern do not go with the stainless over the aluminum screws the factory team comes with.
Yes the bleeding caps do come in handy, have them on both T4 and B4
nwilcox88 is offline
Old 08-31-2005, 01:53 PM
  #573
The ft t4 does not include aluminum screws, and I can't really imagine using them anywhere on the kit. I've used the lunsford titanium screws, and found them to be pretty trick. But, you may want to pre-tap some of the parts with a regular screw.
071crazy is offline
Old 08-31-2005, 03:17 PM
  #574
jamescam's Avatar
Did the Lunsford titanium screws strip easy? I bought an off brand titanium set for my B4 and they were junk.
The stainless steel screws shouldn't add any weight over the factory screws should they? They are both steel.
jamescam is offline
Old 08-31-2005, 07:57 PM
  #575
JoshR 85's Avatar
HeY!!!
no they are the same weight, but yeah i would pre tap the holes so they will go in easier so they wont strip out....
LaTa JoSh
JoshR 85 is offline
Old 08-31-2005, 09:24 PM
  #576
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
i just purchased a factory team b4 and was wondering if anybody has put a high powered brushless into their setup (ex. hacker/neo). specifically i am referring to the novak gtb 5.5 since i have one coming soon (for my xxx-s) but would like to try it in my b4 also. when i check out the AE setup sheets they typically run 12-14 turn motors and the velociti is gonna be equivalent to a 9 turn. any recommendations on changes to my setup to handle the torque? stronger outdrives? heavier oil/springs?
thanks for any help.
tr1kstanc3 is offline
Old 08-31-2005, 10:39 PM
  #577
microrcdude's Avatar
Trader Rating: 70 (100%+)
it should be fine. We used to run 8t drag motors in our B4's, all we did was change to a stiffer spring
microrcdude is offline
Old 08-31-2005, 11:16 PM
  #578
jamescam's Avatar
I learn by sharing information and as such here is my FT B4 and a run down of my tweaks. Starting from the back to the front:
- Gear Cover: I replaced the Stock Clear Gear cover with an RPM Gear Cover that seems to hold out dirt better.
- Wing Mounts: Blue Aluminum just looks pretty.
- Wing clips: Took an extra long body clip and snipped it down to fit.
- Screws: I tried to save money and buy a Lunsford knock off and ended up stripping 3 heads, if you want titanium go with Lunsford more expensive but worth it.
- Receiver: On the Spektrum Receiver you can reposition the wire to come out the side which is what I did here.
- ESC Wire: On either side of the battery box I placed small white wire holders that can be picked up at Radio Shack. These make sure the ESC wire stays flat and in place as it runs under the batteries.
- Battery Strap Thumb Screws: The best $7 I spent on this car, these are a must for any B4/T4!
- On/Off Wire: I glued a heat shrink tube to the right inside wall of the chasis spliced it open and run my ESC On/Off wire through it to keep things safe & tidy.
- Front body post: Removed and placed velcro up front on either side of the chasis and inside the buggy body.
- Front Bumper: After I cracked the stock bumper I replaced with a little larger RPM front bumper that seems to hold up better.
Attached Thumbnails RC10B4/T4 Forum-b4.jpg
jamescam is offline
Old 09-01-2005, 06:42 AM
  #579
Nick111's Avatar
The blue wing mounts may look pretty but if you tend to crash, you might want to stay away from them. You will end up breaking shock towers and tranny cases, they have no flex. The force has to go somewhere.
tr1kstanc3, you might want to take a look at the GT Heavy Duty outdrives. The ones that come with the kit are the lightweight ones. They wear with a mild mod motor, and im sure they will wear faster with a decent brushless. The Heavy Duty GT ones last forever, and they also give a little more weight on the rear end.
Nick111 is offline
Old 09-01-2005, 06:49 AM
  #580
Looks like a pretty nice ride. I agree with Nick on the wing mount, it might create some breakage issues later. At some point, you might want to consider going back to the stock front bumper. If you nosedive on a jump, it looks like that rpm bumper could flip the car much easier.
071crazy is offline
Old 09-01-2005, 06:55 AM
  #581
Actually, some of the lunsford screws did strip. In particular, some of the ones that connect the rear brace to the chassis (the one that also connects to the shock tower and camber links. Turns out that they decided to use button-nead screws for this area. I think they would've been fine if they were a regular hex head. I still thought they were very nice, just need to pretap things very well. Would I buy them again? probably not. They do save a bunch of weight and add bling, but I'd rather spend that cash elsewhere.
071crazy is offline
Old 09-01-2005, 06:57 AM
  #582
jamescam's Avatar
Good point on the wing mount, I haven't raced it since these were added. I don't think I will be going back to the stock bumper though, I went through 2 and have had nothing but good luck with this one. I would have to be pretty vertical to flip with it as it curves up further than the stock. I did recently pick up a T4 so I won't be racing this newly as much so for now I will leave the wing mounts on. Has anyone tried the Lunsford Quick Tune Shock Mounts? I'm curious as to how well they hold up under stress. They are titanium so i have to think they can take a good beating.
If I were going to race this full time I would change out the shock caps with the Yokomo bleeder caps and light weight slipper plate.
jamescam is offline
Old 09-01-2005, 07:29 AM
  #583
tr1kstanc3's Avatar
Nick111-
you have a link to those heavy duty outdrives? thanks. this is my first time owning a 2wd buggy since the days of the jrx-pro so sorry for being so noob.
Old 09-01-2005, 12:40 PM
  #584
Nick111's Avatar
I don't have a link, however I do have part #'s
RC10GT/T2 Left Diff Outdrive - #7668 - $7.50
RC10GT/T2 Right Diff Outdrive - #7667 - $7.50
Nick111 is offline
Old 09-01-2005, 12:51 PM
  #585
jamescam's Avatar
Lets see some other rides and tips
jamescam is offline
